![]() Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
The point was you can not judge a head in a power adder situation. Did you not read this thread and all the posts?
Of course not! Your post is contradicts your own build. Anytime, any power adder, (or not) when VE and/or combustion efficiency is improved you will improve power. (VE is always king ) If your base HP is more than my base HP and we run the same power adder I'm not likely to beat you. At some point the lesser motor chokes and adding more power adder becomes counterproductive. The more efficient motor can continue adding power adder beyond the lesser motor before it hits its choke point. |
My Half AN Injun..... |
| Closed Thread |
