Old 09-25-2016, 10:23 AM
Originally Posted by Frank69 View Post
I installed new sockets and new bulbs and tested all of them. All worked well and were tight.
I can't count the times that I've had to tweak/bend the wires on new bulbs so they would make contact when you put them in the socket. And just because a socket sticks in and twists tight doesn't mean the brass socket contacts are tight against the flatwire in the printed circuit.
The low brake fluid sensor is not connected properly but it never has been as long as I can remember.
Wouldn't worry about that for now. The wire to it and the e-brake switch wire are spliced together at the bulkhead connector. So got to get the e-brake straightened out and the other will work when you hook it up right.
Still wonder why the alt and oil lite and everything else works and this temp lite is not being agreeable!
Somewhere someplace something isn't making contact like it should. Bulb fit in the socket, socket to printed circuit contact, Poor terminal contact between connector/plug-in and printed circuit...And could be a break, tear or defect on one of the flatwires in the printed circuit.
Other than access these are about as simple as it gets when it comes to diagnose and repair.
Just gonna have to dig in and get er done
Clay
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
