#601
On track days I like picking out 2 different types of cars to run..either newer cars that are quick or cars that launch hard with shorter gears,more stall,louder and more dragstrip oriented.Its fun running down the shortgear cars when they start to run out of gear.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 Last edited by ta man; 12-22-2016 at 01:02 PM. |
#602
TAMan, you defenetely influencing what I am doing with my car now too, the only difference will be my car's got a Dana 60 and tallest gear is 3.54's. I am almost done with it will be hitting the track 1/8 mile January.
#603
Thanks,that's the best thing about this forum we influence and help each other.I honestly never thought the current combination would dip into the tens and 60 ft 1.56.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
#604
Ta Man, you said you are planning on going with a new converter, who are you going to use this go around since Continental is no longer? My car is down right now getting the Northwind intake with portwork, Race Pro mufflers to replace my flowmasters (full 3 inch system), Coilovers for the front, QA1 double adjustables for the rear, a new converter from PTC, ATI, or BTE - probably around a 3800 stall 10 inch unit, and 28 inch tires on a 15 inch wheel to replace my 26 inch radials.
1980 Trans Am - Street/Strip 462 Best: 7.08@95 with 1.49 60' in the 1/8th. [email protected] in the 1/4. N/A, 3700 lbs, 3.42's, Pump Gas. Admin of Pure Pontiac Powered Outlaws on Facebook. |
#605
That was one of the plans a while back to dip into the 10's when I was running low 11's.I figured I needed a bit more gear and a 3800 to 4000 stall to do it.I'm not directly familiar with any companies other than what guys here recommend.
Now I'm back to what has worked add power!Trying to achieve as much street friendly power out of the SD KRE's. I'm always worried about overpowering the stock suspension on my car.Its a simple setup just CE 3 ways front and back.No traction aids at all.Its another part of the car that just puzzles people that have never seen the car.I know the day will come where I'm stuck at a certain et and I'm going to need the higher stall speed and a bit more gearing but at the same time a overhaul of the suspension will be needed.
#606
I was really happy with the custom Hughes converter in my '67 Firebird. I believe it was a 10.5". It would flash to 35'ish off the line, but was VERY driveable around town and on the highway. I drove from Houston to Dallas, and Houston to Corpus Christi with it, and no problems.
I'd like to see you advance your cam 1 or 2 more degrees, and keep the 3.08's. I think it would knock your 60' a few hundredths, which virtually always lowers the e.t.. I think it would narrow your shift/trap spread, too.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
#607
Lee I'm thinking it needs a 2.41 and run the Texas Mile in Beeville
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
#608
Must be some guys flying by the end!
#609
ATI or other good brand 3800 stall converter could be your next ET gainer.
#610
Getting over 150mph starts getting to be a HP issue with our older non aero vehicles.
#611
Maybe I'll get to run it with the '73 Firebird :-) It would be fun to have a GROUP of us show up and run it together!
#612
Lee I think as long as you have correct speed rated tires for your MPH anything goes for tires. And you need fireproof driving gloves regardless of speed. Traction is an issue also a balance of traction and gears to get there with a good speed. Interesting thing is by 1/2 mile most cars are within 20 mph in the full mile for many cars.
I've toyed with it in the '81 when I get the new 455 in it and the 3.08s -or tossing my 78's original 2.56 rear in one! It would only pull 130s @ 4000 at Texas World with the stock 180 HP 400 and 2.56s, most of the road course was in second!
#613
Skip, none of the 1/2-mile or longer races allow drag radials - none of the races held in Texas in the last few years, anyways. I haven't re-checked since I sold the wagon (a bit over a year ago now) but doubt the rules have changed.
#614
Question on the Strange Dana60 tapered axle bearings: are the outer races a slip-fit? and shouldn't they be a genuine press-fit? 4L80 should get my Street/Strip goals...if i ever REMOVE the TH400.
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
#615
Half inch stud, the axle bearings are pressed fit green bearings RP400's, thanks for the tips on the gear oil.
#616
Lee I think street radials correctly speed rated are. there are many that have a 200 treadwear they allow at open road race track days and autocrossed that might work and be a little sticky.
4.6 TIRES: DOT-approved tires in good condition are required to be used. The tire speed rating must exceed the speed rating that the car is attempting to achieve. For more info on speed ratings: http://www.tirerack.com/tires/tirete....jsp?techid=35 4.6.1 All tires must have an equal (or greater) Load Carrying Rating and Speed Rating than the original (OEM) manufacturer’s requirement. 4.6.2 HIGHLY RECOMMENDED: The use of tires with better ratings than OEM is recommended. 4.6.3 Drag radials (DOT spec) are not approved. *Drag radials are approved ONLY at The Houston ½ Mile. 4.6.4 Drag racing (DOT-spec) “skinnies” or front runners are not approved. 4.6.5 Land Speed tires are NOT Approved without the approval of the Chief of Tech or The Race Director.
#617
Roadpaver to the front. I remember Darby picking up with it. With that low 1st gearset and adding 3.42's you got the same combo.
#618
Just realized I never posted these pictures.Spring is approaching, soon time to start wrenching.No time bomb shortblock anymore.
#619
![]() Looking forward to spring in Oklahoma, also. was 72 here, Monday!
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
#620
Much lighter pistons and rods,balanced assembly,zero decked and compression is being increased as well as a few other minor tweaks.
