Old 01-16-2017, 02:07 PM
moto-d's Avatar
moto-d moto-d is offline
Did you run a single line from the pump to the carb then, or go to the two line system with the fuel filter up by the carb?
Also, did you switch to 3/8 main fuel line to match the feed? I've already got 5/16 and that **** costs a fortune to ship.
'67 GTO Hardtop Montreaux Blue 400/400
'67 GTO Hardtop Regimental Red/Black Cordova top/400/4-speed
'67 Bonneville Ragtop Montego Cream 400/400
Old 01-16-2017, 02:38 PM
helmerrock helmerrock is offline
I bought the 3/8 front to back line on the 67 I have now. I got the pump with the return line fttting from the pump. The pump is designed for 5/16 input but the 3/8 hose clamps on fine with no issues. I used the steel line from the pump to carb that allowed the use of an in-line filter. Looks stock but I think if the return was on the pump the steel line to carb had no filter (just the quadrajet inlet filter). Since you already have the 5/16 line from the tank I would go ahead and use it. You should be fine to connect the 3/8 sending unit to a 5/16 line without a problem. By all means you should use a return line, especially with todays available gas that practically boils at room temperature!
