So Ryan, Eric and Jake have been busting their foofa-valves on this thing again this week.
The Sanden A/C compressor was mocked up so the boys could work out what belts I need to run ![]() ![]() Test-fitting the condenser mount & drier mount - it was great Pontiac thoughtfully designed the radiator support with this recess that makes a perfect mount for the receiver-drier ![]() ![]() Brackets to mount the evaporator under the dash - all powdercoated in Oxytech gear (Wet Look Black for gloss stuff, Ebony Texture for the matte stuff) ![]() Yay spaghetti - Jake has done a KILLER job on this thing's wiring given the crap he was handed ![]() ![]() ![]() ![]() ![]() Ryan discovered the gantry shock mount the car used to have in the front-end wouldn't work with where the power steering pump & A/C compressor now lived so he relocated the shocks to a more conventional spot down beside the chassis. He also found my car was using stock C10 Chevy pick-up front shocks. As they were 100% SNAFU Ryan thoughtfully ordered me some more so it should ride nicely with all the work I'm about to put into flash new bits in the front-end. ![]() At least being bagged makes it easier to work on ![]() This is how the custom fan shroud on the other page mounts up. Hopefully my SPAL turns up soon? ![]() I've ordered a bunch of parts and have made myself fantastically broke. On their way are: - quick-ratio steering box - new inner & outer tie-rods - new drag link (centre section) - new idler arm - rag joint/steering coupler rebuild kit - new upper control arm bushes & shafts - new engine mounts - new carpet - new kick panels - new C-pillar panels (to get wrapped in hoodliner) - new headunit - whole new disc brake kit That last one is on top of the Castlemaine Rod Shop spindles to take HQ Kingswood (Aussie Holden) calipers. I've got a mate with a '62 Bonneville so i'll probably pass that all on to him as he wants to run 14in wheels and I think he'll squeak that out with HQ brakes whereas I want 15s or 17s and am happy to go with bigger brakes. The kit I've ordered is from Master Power Brakes - http://www.mpbrakes.com/1964-pontiac...s?filter_name= ![]() I should have it in a few weeks and will bash the new front-end in one Saturday. At that point hopefully I'll have time to pull the steering column out and give it a lick of paint. Or powdercoat. Whatever. It's only money, right? |
You can get them on Amazon or Ebay for about $50-$70 USD total, P/N's if you are interested: http://forums.maxperformanceinc.com/...0&postcount=15
1964 Catalina 2+2 4sp, 421 Tri-power 1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM, Holley EFI, DIS ignition. 1969 GTO 467, Edelbrock 325 CFM, Terminator EFI 1969 Firebird Convertible |
who makes the compressor mounting bracket and what is part #
thank you [QUOTE=Marv;5708047]So Ryan, Eric and Jake have been busting their foofa-valves on this thing again this week. The Sanden A/C compressor was mocked up so the boys could work out what belts I need to run ![]() QUOTE]
Donate Life 6-7-04 Liver Transplant Recipitant http://www.donatelife.net/ U S A for Organ Donation Thank You
