#141
Old 12-02-2016, 03:03 PM
63Banshee's Avatar
63Banshee 63Banshee is offline
Originally Posted by elefantrider View Post
WTB- complete 62 instrument/speedo cluster.
Get my PM?
  #142
Old 12-03-2016, 04:37 AM
elefantrider's Avatar
elefantrider elefantrider is offline
Please send pics via email or PM so I know what I'm talking about before I call.
  #143
Old 12-04-2016, 01:32 AM
63Banshee's Avatar
Can't send pics from this site to email or PM. You asked me for a 326. I've got a couple complete. One is a low mile rebuild. You have my number --
  #144
Old 12-09-2016, 12:42 PM
1979birds 1979birds is offline
Default Parking lamps
WTB 62 Lemans front left and right parking lamps. Anybody have any for sale?
  #145
Old 02-13-2017, 06:06 PM
Sanduners's Avatar
Sanduners Sanduners is offline
Default Dipstick for trophy 4 engine
Just the dipstick, should be same as a 389 I believe. Thanks
  #146
Old 02-13-2017, 06:31 PM
tom s tom s is offline
replied on other thread.Tom
  #147
Old 03-03-2017, 12:09 PM
63gpman's Avatar
63gpman 63gpman is offline
have a friend doing a 61 wagon build and is looking for a front valance in good condition and a rear 3 piece rear gate window.
Call Gary at 507-421-1917 if you have something for him. Lives in Rochester, MN but makes trips to swap meets around such as Jefferson WI and Iowa.
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
  #148
Old 03-10-2017, 12:51 AM
wojo1963 wojo1963 is offline
Default Universal joint
I am looking for the rear axle u joint replacement or rebuild kit.
Any leads will be appreciated.
I have a 336.
  #149
Old 03-10-2017, 12:53 AM
Any leads will be appreciated. Have 336
  #150
Old 03-10-2017, 01:30 PM
c5farmer's Avatar
c5farmer c5farmer is offline
Default Ujoints
Craig Mosely of the Little Indians chapter has made them by combining two different Ujoints. He switched the caps on Ujoints from NAPA. Contact him from the little Indians web site for the part numbers.
  #151
Old 03-13-2017, 01:14 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Search the parts houses, they are out there if you look. Aftermarket number is 3093A
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
  #152
Old 03-13-2017, 08:37 PM
jusjay's Avatar
jusjay jusjay is offline
Is there a difference between years and engine/transmission?
  #153
Old 03-13-2017, 09:50 PM
Keith,
I have searched every site i can think of for a u joint no. 3039a. Nothing comes up as a u joint, many other parts do. Do have a manufacturer or supplier who catalogs by the no. 3039a.
Ps. When ever i go to a part supplier site and search for a 1963 lemans, it just comes back with 1.125 cap and 2.56 cross member which is the standard for GM during 50s and 60s. Except for our favorite little car.
  #154
Old 03-23-2017, 11:48 PM
Tom63LeMans's Avatar
Tom63LeMans Tom63LeMans is offline
I need two of the left side instrument cluster mounting brackets. This is the bracket that attaches to the instrument panel with 2 screws and has the stud that goes into the dash. I built a custom insert for my panel, modified my left bracket to work on both sides and promptly lost it.
I also need one usable curved head bumper bolt.
Thanks,
Tom
1963 Lemans -428 +.030, SD Perf KRE heads, turbo 350, 9" Ford 3:90, 11.01@121
1956 Chieftain gasser, 461 stroked 400, SD Perf ported E-heads, turbo 400, Dana 3:70 10.40@125
  #155
Old 03-24-2017, 02:51 PM
All 61-63 cars use the same U-joint. They are getting very hard to find.
Keith Collier
Tech advisor
POCI.org
  #156
Old 03-24-2017, 03:01 PM
c5farmer's Avatar
Default ujoint
A member of the Little Indians club found an answer for axle ujoints by combining NAPA 315G and NAPA 316 joints. Switching the caps worked.
  #157
Old 03-24-2017, 09:33 PM
Thumbs up
Mr. Mosley
Let me know about his find. I went to napa about getting the u joints and they had to order the 315g, but assured me there was no shortage of them. I took them to my machine shop where we reviewed them and found the only obvious difference with oe was the overall width of the napa one was 1/16" or less in width. Having been a structural engineer for over 40 years, i will assure you this would not be the cause of any failure.
The joint has now been pressed into place and the axle is going to be installed tomorrow.
If anyone would like pictures let me know now.
I had also called skf last week and they told me that the bearing cap internals were the same and could be interchanged.
I think everyone should thank Craig for going the extra mile to come up with a solution from a common part source. Everytime this is done will increase the value and dependibility of our autos.
  #158
Old 03-24-2017, 10:00 PM
jusjay's Avatar
From this in Clarks,
http://www.corvair.com/user-cgi/cata...main&page=157B
Got to be the same, wouldn't you think?
  #159
Old 03-24-2017, 10:32 PM
Thumbs up SKF
Craigs work is based on SKF u joints, these cost about $33. For the two. There are a lot of other ujoints that are cheaper, you may save a few bucks on it or you may have something that is not usable. I was checking out GMB joints and found a difference in the cap internals of less than .1 mm, they would not last. Kanters also says they have new ones for the little indian. When you buy the skf you know what you are getting.
We need to come up with more approaches like Craigs and less on scavanging old parts. Old parts are a diminshing return.
  #160
Old 03-26-2017, 09:02 AM
John in Minnesota's Avatar
John in Minnesota John in Minnesota is offline
So shut changes caps. Which one is the one that fits and the one to throw away? The 315G with 316 caps or the 316 with 315G caps? Thanks John.
