Old 03-30-2017, 10:43 PM
Scott Stoneburg's Avatar
Default painting rally IIs
Looking for some help with a decision. I'm gonna paint a set of rally IIs for my firebird. Should I paint the rims black or gray with silver "spokes or paint them the matching body car color with silver spokes?
Old 03-30-2017, 10:47 PM
MUSLCAH MUSLCAH is offline
Grey with Silver spokes....did mine that way.....a lot of eye strain..taping off 4 wheels with fine line tape.
Old 03-30-2017, 11:04 PM
I had them painted to match the body before. But I'm repainting the car bright blue. Here's what they looked like in green
Old 03-30-2017, 11:35 PM
I think Pontiac did it right...with the grey and silver spoke.....the wheels had their own look....but that's just me.
Old 03-31-2017, 07:38 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Hard to beat the original colors of charcoal gray and silver.
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 03-31-2017, 09:15 AM
Tempest's Avatar
Tempest Tempest is offline
instead of using 'fine line' tape and carefully masking the edges, .....spray the entire wheel silver, then once the silver dries, mask over the spokes completely (cover the edges of the spokes), and with an exacto knife, cut along the edges of the spokes and peel away the tape from the lug nut area. Then paint the grey.
IMO, body color Rally 2's don't look as good as the grey/silver
Hope this makes sense
Name:	Rally 2 Wheels painted_WEB.jpg
ID:	451079   Click image for larger version
Old 03-31-2017, 10:51 AM
1966Lemans's Avatar
1966Lemans 1966Lemans is online now
'67 Piper Cherokee
'66 Lemans
Old 03-31-2017, 11:06 AM
Yes. This sounds like the easier way to do it.
Old 03-31-2017, 11:21 AM
1970GPJ400 1970GPJ400 is offline
I used the Ames pre-cut masking kit. (Page 266 in new catalogue) Masking kit cost $8 for mask only or $44 with correct color paints. Used kit to paint 5 Rally II's. Best way to go in my opinion.
Old 03-31-2017, 01:00 PM
It's not just you, when you're right you're right...lol
Easier to mask them off with WIDE blue masking tape. It's soft and conforms to the raised edges of the color break on the spokes...then take an x-acto and cut around the visible raised line. Order of color is paint the entire wheel the argent silver, then mask and spray the charcoal.
Old 03-31-2017, 01:05 PM
Ooops...got treed by Tempest...lol
Anyway, here is my result...
Old 03-31-2017, 01:11 PM
This next photo demonstrates why you should not ignore the backside of the wheel. It should be a gloss light machine-gray. It DOES show.
Old 03-31-2017, 02:22 PM
Sounds like the charcoal gray and silver is the most popular. I'll look into the kit from Ames. I'll be using without trim rings. Drag strips don't like trim rings because of the possibility of them flying off. Or so I was told.
Old 03-31-2017, 02:54 PM
78w72 78w72 is offline
& they look way better w/out trim rings!
Old 03-31-2017, 03:55 PM
Tempest's Avatar
here is the finished wheel, (with trim ring)
don't go too dark with the grey,
sorry Greg,
Name:	Tempest RF wheel.jpg
Old 03-31-2017, 08:31 PM
You are right Tempest about the charcoal. With the ones I did, I literally took two colors off the shelf at Wal-Mart using the 'looks about right to me' method. The next set I do will definitely be a paler shade of gray/charcoal and less metalflake.
They DID look good on my old T/A though!
Old 03-31-2017, 09:10 PM
I found some Honda 2 tone colors in my color book that are pretty close in color.....and 2 coats of clear over it....oh my !
Old 03-31-2017, 09:45 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
I used the Duplicolor wheel paint on mine along with the blue tape method. After removing the old paint I primed the wheel with green etching primer followed by a couple light coats of grey primer sealer. Then I sprayed the silver and let them dry overnight. The next day I taped them off and sprayed the dark grey, I think they turned out pretty nice considering who did the job! Now, they are stacked up in my shop because I opted for the 17" rally IIs from Year One! The first picture shows the wheel before I started. Next three are etching primer, primer sealer and silver finish coat.
ID:	451106   Click image for larger version
ID:	451116   Click image for larger version
Name:	primer sealer.JPG
ID:	451117   Click image for larger version
Name:	silver first coat.jpg
Old 03-31-2017, 09:50 PM
fyrffytr1's Avatar
Here are the tape pictures and one of the finished wheel. When I taped the wheel off I applied pressure to the edges with the side of a Phillips screwdriver shaft.By rubbing the shaft against the edge the tape separated and I was able to peel the unwanted portion off easily.
ID:	451119   Click image for larger version
ID:	451120   Click image for larger version
ID:	451121   Click image for larger version
ID:	451122   Click image for larger version
Name:	finished  wheel.JPG
Old 03-31-2017, 10:39 PM
Iam an old body man.....I just taped them off...like a set of flames ,or a two tone car or motorcycle tank....then went over the tape with my heat gun,to lock the tape down.....leave the razor blades for the kids.....lol
