Old 03-30-2017, 05:32 PM
Steve Shively Steve Shively is offline
Smile Need driveshaft for 70-72 A bodyTH400 trans 2 DR
Need a proper driveshaft for my 1971 Lemans, has TH400 transmission in it, mine is too tight, not enough play in it. A good used one will do, thank you!
Old 03-30-2017, 09:48 PM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
I have one from a TH400 70 GTO. Email [email protected] can get pictures Saturday
John
My Website www.minnesota-muscle.com
Old 03-31-2017, 09:15 AM
ROCKETMAN269V's Avatar
ROCKETMAN269V ROCKETMAN269V is offline
Originally Posted by Steve Shively View Post
.....has TH400 transmission in it, mine is too tight, not enough play in it.....
What rear end do you have? That may be the problem. I have a book that lists the length of driveshafts by application. Measure the one that you have now; center to center on the u-joints. You can email me to discuss: [email protected]. Thanks, Bob.
Old 03-31-2017, 11:02 AM
Whether 8.2 Pontiac 10 bolt, '68-70 BUICK 8.2 10 bolt, Type "O" Olds 10 bolt, & all Chevy 12 bolt whether factory 3R pinion flange or spicer 1310 (will need adaptor Ujoint), ALL for this application, will use the same exact length stock driveshaft. 55 3/8", center to center, with the medium length ('67-75) turbo 400 yoke. Throw into the mix, the shorty (Seville) style yoke, or one of the really long yokes like used in a '70 T/A with T400, that will throw off measurement.
With a 8.5 A-body rear swapped in, will need oem driveshaft to be cut down 7/8", so 54.5" center to center length with correct med length T400 yoke for '68-72 GTO with T400 or big output shaft Muncie. Myself & 2 others in N Texas pioneered the 8.5 A body rear swap in the early 90's, have had over 5 dozen oem driveshafts cut down for that swap, & have parted to the ground over 400 68-72 GM Abodys including many Olds & Buicks. If they have had nice driveshafts in them, they have been measured, marked with paintpen, & made it to the driveshaft barrels.
Old 03-31-2017, 04:01 PM
Looks to have factory BOP 8.2 rear in it.
Old 04-01-2017, 01:39 PM
GTO JOHN's Avatar
I have a TH400 driveshaft 55 3/8 center to center out of a 69 GTO. The lower one in the picture
John
Old 04-03-2017, 08:04 PM
Pulled mine today, center to center is 55 1/2" long.
Old 04-03-2017, 08:35 PM
GTO JOHN's Avatar
My measurement was only 1/8" difference from yours, I have the correct shaft if you still need it,
John
Old 04-04-2017, 04:56 PM
Once weather permits again, raining lately, I am going to take a closer look at differential & suspension, not sure what to think. Maybe question in Tech...
Old 04-05-2017, 09:26 AM
......mine is too tight, not enough play in it........
If you're checking the "play" with the rear end hanging, such as on a lift, it may seem to be too long. I've had to jack up the rear on some vehicles to remove the driveshaft. As the rear end drops, the lower control arms swing in an arc, causing the pinion yoke to move forward and tightening up the slack between the transmission and the rear end. This can also be exaggerated by worn control arm bushings or rear shocks that are too long. Just food for Thought.
Old 05-02-2017, 07:32 PM
John, did receive my money order for the driveshaft?
Old 05-02-2017, 07:58 PM
GTO JOHN's Avatar
Yes I did. I was out of town at the Jefferson swap last weekend. Shipping this week, Thanks!
John
Old 05-02-2017, 08:55 PM
No problem, hope it went well there!
Old 05-11-2017, 08:45 AM
John, your driveshaft solved my problem thank you!
