Old 03-10-2017, 06:51 PM
S Courter's Avatar
S Courter S Courter is offline
Default My 65 Lemans LS1 swap.
Bought this 65 Lemans off CL Dec. 2015. Solid car with all new interior, new tires, new exhaust, 3:73 posi and 350 turbo. Motor was absent. I have really enjoyed my LS1 powered 64 Tempest so decided to do it again on this 65. On the 64 I used BRP Hotrods pricey motor mounts and headers. This swap I am using adapter plates with Chevy motor mounts and the stock LS1 F body exhaust manifolds to save $$. I purchased the LS1/4L60E complete with all accessories, wiring, ecm, fans and battery cables out of a 99 Trans Am with 114k miles. Price was $3400 delivered to my door. The first thing I did was remove the front clip to make installation easier. Next I removed all body mount bolts except the rear ones. Those two I just loosened. I have found it easier to raise the front of the body to make engine/tranny install easier. I will replace all body mounts before bolting body down. Next I removed the original F-body oil pan and installed a GM performance oil pan part number 19212593. Cost $194. I replaced the front seal in the transmission, reinstalled the torque convertor and bolted transmission back onto the motor. Getting it ready to drop in the car. Will update as I progress.
Cost $3400 LS1/4L60E
$194 oil pan
ID:	449253   Click image for larger version
ID:	449254   Click image for larger version
ID:	449255   Click image for larger version
ID:	449258   Click image for larger version
Steve
71 Pontiac GT-37 400 4 spd (sold)
71 Formula 400 turbo 400 (sold)
01 Firebird T/A WS6 auto (fun)
64 Tempest Post car LS1/4L60E (Love It!)
65 Lemans Post car LS1/4L60E (More Fun)(sold)
73 Lemans GT 400/auto 1 owner 52k miles
69 El Camino LS1/4L65E (Awesome)
70 Pontiac GTO Convertible 400/400 Original (sold)
69 Olds Cutlass S W31 Numbers matching 4Spd 3:91 one of 569
72 Post Coupe GTO 400/400 1 of 60 built 1 owner original
Old 03-11-2017, 03:37 PM
gtospieg gtospieg is offline
Nice...waiting for more updates
Old 03-14-2017, 08:08 PM
S Courter's Avatar
I forgot to mention that I also unbolted the steering shaft from the gear box to facilitate raising the body. I purchased aluminum adapter plates and 65 Chevelle frame mounts off E-bay. Sourced 65 Chevelle motor mounts locally. Bolted the frame mounts to frame and adapter plates and motor mounts to LS1. I raised the front of the body up about 6 inches on each side and secured with wood blocks. I then slid the motor and trans into place with an engine hoist and a floor jack under the trans. Everything went smoothly and the motor dropped perfectly onto the mounts. As I was checking clearance under the motor I noticed the pan was almost touching the center link. Hmm, that wasn't going to work. Since I had the 64 sitting close by I went to check how high that motor was sitting in the chassis. I measured the distance from the tow loop, on the cross member, up to the bottom of the pan. It measured approx. 3.125 inches. The motor in the 65 needed to be raised 1 inch to be the same. My solution to this problem was to cut a piece of heavy wall tubing long enough to fit inside the block mounts and weld it on top of the frame mount. I made sure the motor was level side to side and the transmission tail shaft was centered between the frame rails. That put the pan 3.250 above the tow hook. That's .125 inches higher but should be no problem and gives clearance from the cross link. I will tackle the transmission cross member next.
Adapter plates $30
Frame mounts $65
Block mounts $12
ID:	449629   Click image for larger version
ID:	449630   Click image for larger version
ID:	449631   Click image for larger version
ID:	449632   Click image for larger version
Steve
Old 04-03-2017, 10:54 PM
S Courter's Avatar
O.K. Getting the rear transmission built involved getting body bolted back down on the chassis and keeping the transmission tail shaft as high in the transmission tunnel as possible. But before I did that I removed the drivers side remaining rear body bolt and jacked the body up to remove the stock 5/16 fuel line and installed a new 3/8 fuel line from Inline Tube. At the front you will need to bend the fuel line up along the firewall near the steering column. This will put it close to the fuel inlet on the fuel rail. Reinstalled the rear body bolt with a new mount. In order to drop the front of the body back into position it is necessary to cut the transmission tunnel for clearance around the bell housing and transmission oil lines. This is somewhat trial and error. I have included a picture to show some of what I did. Once I had the clearance I needed and the body bolted back down I welded in new metal to close up the floor. The transmission cross member is made from heavy wall square tubing and a piece of 4 inch c-channel for the actual mount to set on. My transmission cross member mimics the one I got from BPR Hot rods with their mount kit. As I did with my 64 I purchased a fuel tank kit from Speedway Motors. This kit includes a larger capacity tank with built in baffles that surround the pump to prevent starving, a Bosch intank fuel pump, and a sending unit. It is necessary to assemble the pump and sending unit and install them in the tank. Follow the directions included and you will be ok.. I purchased An6 fittings and push on high pressure hose to hook everything up. I also used the WIX 33737 filter/ regulator to handle fuel flow. I mounted this unit close to the tank to minimize the length of the fuel return line needed. These filters were stock on LS powered Corvettes and provide the correct fuel pressure to the motor and return excess back to tank. I bought a 37 degree An flaring tool to flare the New 3/8 fuel line to accept An6 fittings. I have found the only way to get push on high pressure hose installed on the fittings is to soak the hose in boiling water and have the fitting in a vise. You can then force the hose on because it is soft. Once it cools no leaks. It is pretty obvious how you wire up the pump and sending unit. Make sure you have good grounds. The pictures are out of order.
More to come.
Transmission cross member-$0 Stuff I had
Tanks Inc. Tank Kit--$499
Wix filter/reg 33737-$47
3/8 Fuel line Inline Tube-$104
High pressure fuel hose and 6an fittings-$150 If you would like a break down PM me
ID:	451418   Click image for larger version
ID:	451419   Click image for larger version
ID:	451420   Click image for larger version
ID:	451421   Click image for larger version
Steve
Old 04-03-2017, 10:56 PM
S Courter's Avatar
Couple more pictures.
ID:	451423   Click image for larger version
ID:	451424   Click image for larger version
Steve
Old 04-20-2017, 07:34 PM
S Courter's Avatar
I used headers on the 64 but am using the stock F-body exhaust manifolds on this swap. They fit with no clearance issues. The cats came with the motor so I cut the mounting flanges off leaving just a short nub of pipe. I removed all the EGR mounting points from the manifolds and welded them shut. I also welded shut the O2 sensor on the drivers side manifold as it is not located where I could use it. I fabricated down pipes to hook up to the existing exhaust system that was on the car. This included adding O2 sensor bungs on both sides. There is also an opening on the intake just behind the throttle body that needs to be plugged. I purchased a block off plate for it on E-bay.
For cooling I am using the stock F-body dual fan set up and an aluminum radiator. The fans fit the radiator real nice and came with the motor. I fabricated mounting brackets to attach the fans to the core support. The plastic fan shroud had to be trimmed around the inlet and outlet. The outlet on the LS1 does not point toward the radiator so I purchased an outlet the swivels so it can be directed down to the outlet. This also allows a spot to install a small hose barb so you can attach the steam hose from the motor. This hose is normally attached to the F-Body radiator. For radiator hoses I used part of a early 70s F-body upper hose for the lower on this swap and a stock 99 F-body upper hose for the upper on this swap. I cut this in half and reversed one end and installed a coupler. It works. Heater hoses are the same as any car. There is some clearance issues between the heater core nipples and the rear of the coil mounting brackets but hoses will go on.
EGR block off plate $9
Hoses $40
Swivel outlet $57
ID:	452574   Click image for larger version
ID:	452575   Click image for larger version
ID:	452576   Click image for larger version
ID:	452577   Click image for larger version
Steve
Old 04-23-2017, 03:03 AM
pestwagon64 pestwagon64 is offline
Hey Steve! Its Steve from Los Banos. Still "working" on the 64! Replaced the passenger floor pan (broken heater core damage/rust) and redid/welded like original the radio area on the dash (previous owner had installed a pull out radio). FINALLY drilled out a 2 1/2 inch hole in the dash for the harness. Am installing the ECM in the glove box area (not gonna put in A/C). Just needs wiring all connected at this point. I'm taking my time with my work commitments and poor shop conditions(in garage nw finally) and the 65 4 door I recently restored...
Wondering if you're going to spring for those Dakota Digital Gauges again in this 1965 LS1 conversion car? Wthey "worth it" or not installing them on your 64? I'm considering black gauge set with red needles ...
Old 04-23-2017, 10:24 AM
Tim john Tim john is offline
Nice informative details Steve, thank you for sharing.
Tim john---
Old 04-23-2017, 07:18 PM
S Courter's Avatar
Steve...Good to hear you are still working on it. Hope you have it up and running soon. Yes, I already bought the Dakota Digital Gauges for the 65. IMO totally worth it. I bought silver with blue back light this time as the 65 has blue interior. The 65 is very close to getting paint. I bought a 67 Chevelle 300 deluxe 2 door a couple weeks ago and already have a 5.3 sitting in my shop to go in it. Going to do a Muncie 4 speed in this car. It needs a lot of work but I like projects. I am going with the Dakota Digital gauges for it also.
Steve
Steve
Old 04-25-2017, 10:01 AM
S Courter's Avatar
The F-body LS1 alternator needs to be relocated as its position interferes with the power steering box. I used a relocation kit from Speedway motors which relocates the power steering pump and alternator up and provides the clearance needed. The kit comes with a new belt also. I used the stock F-body power steering lines. I cut the metric o-ring fitting off the high pressure hose and installed the correct flare fitting and reflared the line. I had to tweek the metal tube part of the line to get it into place but it looks and works great. I used a universal cold air intake purchased on E-bay. I also purchased Corvette coil covers to dress up the engine a bit. I am using the stock wiring harness that I received with the LS1. I sent it to Ken Wolkens @StandAlone Solutions in Melborne, Fl. He reworks the harness eliminating all unneeded wiring and adding a relay panel. fuse panel, and OBD port. You can see the relay/fuse panel on the firewall in the third picture. I mounted the OBD port under the dash on the drivers side. He does great work and when the harness comes back everything is labeled and there is an instruction sheet to help figure out where everything goes. I sent the ECM to Ryan VanVels @ LS Solutions in Grand Rapids, Mi. to have it reprogramed. I mounted the ECM above the under hood heater fan cover. It is a little work getting the wiring in place and wiring the relays to the fans, fuel pump, etc. Helps if you understand automotive wiring. Gauges are next. Then we will fire it up. Oh what fun!
Alt relocation kit 481-1004 $160
Cold air intake kit $78
Wiring rework $325
ECM reprogram $150
http://www.standaloneharness.com/ls-engine.html
http://www.ls-solutions.net/
ID:	452918   Click image for larger version
ID:	452919   Click image for larger version
Steve
Old 05-06-2017, 09:30 PM
Jim Doran's Avatar
Jim Doran Jim Doran is offline
Great Stuff. Subscribed !
-Jim Doran-
1965 389 Tripower; 4 speed; convertible
2019 Tesla Model 3 Performance
2016 Chevy SS; Sold
2001 Toyota Tacoma 4x4
2008 Infiniti G35x
Old 05-10-2017, 10:20 PM
S Courter's Avatar
I once again opted for the Dakota Digital VHX gauges. There are cheaper ways to do your gauges but I used them in the 64 and like the looks and everything they offer. They include senders for temp and oil pressure, programmable to use with many different fuel sending units. Have provisions for Hi beam indicator, turn signal indicators, CEL, digital clock, digital odometer and message center. Speedometer is compatible with different signal generators and is adjustable. Another thing I like is that all wiring goes to a central control box and from there a cat. 5 data cable runs to the instrument panel. They come with a comprehensive instruction book. Read carefully, follow them step by step. You can order them with different face colors and different back lighting. I ordered silver gauge face with blue back light because this car has blue interior. They bolt right to the stock dash bezel. Really look good at night. I fastened the control box to a hinged bracket so I could easily access it for initial wire up. When done it swings up under dash out of sight. There are two small push buttons that have to be wired to the control panel and installed somewhere where you can reach them. These are used to program the control center. I mounted them in a small bracket under the dash so they face toward the seat. Painted the bracket black and it is hardly noticeable. You can see them to the left of the control box in the first picture. I cut away all the stock under dash wiring that wouldn't be used. You need to connect the stock Hi beam indicator wire and turn signal indicator wires to the DD control box. I completed all the wiring, dumped 5 gallons of premium in the tank, cycled the fuel pump a couple of times and checked everything for leaks, I had a small drip in the rear at one fitting so I retightened it. That solved it. Hit the key and the motor fired right up!!!!!! WOW gotta love that!!. Sounds good too! Settled down to a nice idle. Tach, fuel, amp, and oil pressure gauges all working. No coolant in it so did not run it too long. Just happy it is running. Car is getting very close to having new paint. Looking forward to driving it. I had the drive shaft shortened and balanced so it is ready to go in the car. You can see the CEL on in the dash picture. Scan tool showed a couple codes related to low fluid level in transmission. Added some tranny fluid and erased the codes. No more CEL. My budget for this swap was $7000 and I spent $6544.
Dakota Digital VHX Gauges $755
Drive shaft service $110
ID:	454286   Click image for larger version
ID:	454287   Click image for larger version
ID:	454288   Click image for larger version
Steve
Old 05-30-2017, 03:39 PM
Jim Doran's Avatar
any updates ? Dash looks great. Spent some time reading up on them. Nice. http://www.dakotadigital.com/index.c...od/prd1077.htm
-Jim Doran-
2016 Chevy SS; Sold
2008 Infiniti G35x
Old 06-01-2017, 07:23 PM
S Courter's Avatar
No updates. Still getting it ready for paint. Did drive it out of shop so I could clean. No brakes so had to push it back in. I think I am going to have to change the front springs as the LS1 does not compress them enough. Will probably have to use SBC front springs. Should have it painted in a couple weeks then reassembly begins.
Steve
Old 06-24-2017, 08:06 PM
S Courter's Avatar
Got the paint shot on the body. Still have the hood and deck lid to do plus the grill surrounds. Then cut and buff. Love the color. Got the brakes bled so I can drive it in and out of the shop. Sits too high in front so will get the SBC front springs installed soon.
Steve
Old 06-24-2017, 10:07 PM
Those may not be light enough. I went with Moroso drag springs;
http://forums.maxperformanceinc.com/...&postcount=134
Old 06-26-2017, 06:52 AM
Jim Doran's Avatar
Nice Color. Fix the stance and it will be killer.
-Jim Doran-
2016 Chevy SS; Sold
2008 Infiniti G35x
Old 06-27-2017, 12:55 AM
Bad As- build!!!
Old 08-05-2017, 12:47 AM
Jim Doran's Avatar
Have you had a chance to drive it yet ?
-Jim Doran-
2016 Chevy SS; Sold
2008 Infiniti G35x
Old 08-05-2017, 09:07 PM
S Courter's Avatar
Jim...Have not driven it except around my yard. My paint work was unacceptable so I sanded it down and hired someone to paint it. He did nice work and I am sanding and buffing it. I will be reassembling it soon?? Hope to get some miles on it yet this summer. I am still enjoying putting miles on my LS1 powered 64 Tempest. Its a great driver.
Steve
