Old 05-01-2017, 08:13 PM
JLMounce JLMounce is offline
I have not done the swap, but have also been researching it. My understanding is that the 4L80e will fit in the trans tunnel without cutting, but may require the use of a BFH to clearance the driver's side for cooling lines.
-Jason
1969 Pontiac Firebird
Old 05-03-2017, 10:39 PM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
For anyone interested, I am fairly convinced this is a very doable swap but I have decided to go back to a TH400 for now and might consider this for next year. If anyone has questions about what I found out so far, let me know.
List of things you'll need:
4L80E Transmission (~$700 from local shops / ~$3000 from builders)
- Jakes Performance here in Texas came highly recommended
Computer Controller, looks easy to setup and use but around $700
Chevy Trans to BOP engine Adapter $75
Speedometer Alteration - Seems to be 3 options:
- Electronic Speedometer (Dakota Digital)
- Adapter to convert electrical to mechanical
- Alternate tail shaft that will provide full mechanical
Throttle Position Sensor (TPS) $120
I was told only concerns about fitting it in the stock trans tunnel are making sure there is clearance for the cooling lines. An awesome fellow PY'er called me and mention that the earlier housings have the cooling lines at the front of the trans about mid-way down, about where a 2004R has them however for later cases, I think he said 96 and later they moved one back to the middle of the trans and higher which would make providing clearance for the cooling lines much harder so I would avoid those.
Now I have some newb questions about the TH400 but will post those in another thread.
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
Old 08-01-2017, 10:04 PM
redhawk44's Avatar
redhawk44 redhawk44 is offline
Good bit of info here, thanks.
Let's make welfare as hard to get as Veterans benefits!
Old 09-16-2017, 05:02 PM
wovenweb's Avatar
wovenweb wovenweb is offline
H
I would suggest selling that bad 200-4R to someone in your Pontiac car club so that hd can use it for his Buick A-body project.
