Jimmy, I am a member of the club but never seem to have time to attend many functions. I was at dyno day a couple weeks ago but got there late. I think we have met, but it has been a while.
Yes we did. Your Firebird in the pic looks red but its orange right? 69 Firebird, Orange with a white top? We did chat for a bit. Thomas is working on the project with me. He's advocating for putting the 2004R back in the car but I could not find a builder in the area.
Jimmy www.firebirdgallery.com 2002 WS6 M6 Trans Am - original owner 1973 Trans Am 455/4-speed 1971 Formula 400/400 1969 GTO 400/400 - 3rd owner 1968 Firebird Convertible 350/200R4 POCI - AAC |
He did, but that was years ago and he couldn't get in touch with him. What trans are you running?
I'm actually more convinced to do the TH400 now and a 4L60E or 4L80E later. The electronics is not hard to manage (albeit expensive) and it will fit. I did some research on the 2004R last night. It was based on a light duty version of the TH350 called the TH200 that was only installed in small engine vehicles in the 70s. It was prone to failure in anything with a larger engine (5.7L and higher was called out in the article). GM tried to improve the transmission and released the 2004R. I know a lot of ppl are quick to recommend it but knowing its history now, I don't particularly care to try again.
I had an 81 Bonneville diesel, and a 78 301 GP with THM200, that expired in under 70,000 miles with no abuse, plus many customer cars that had premature transmission failures. The 200 4R was also steadily improved as GM did their field testing, especially in the late 70s early 80s used in the field testing with customers being the test subjects. One of the key reasons GM lost much of their market share. One other thing is the full electronic controlled transmissions can be adjusted without raising the hood, or crawling under the car, just adjust the TCM from inside the car. The OPs thoughts of using a transmission that was originally designed for tough usage, in heavy vehicles, with engines that were not anemic in stock form, is probably going to be the best path to reliability over the long haul. Most any T400 or 4L80E in stock form will withstand the engines power of 90% of the street cars on PY. Going from the stock 440 ft lb torque rating of either transmission to almost doubling it to 750 ft lb is pretty easily accomplished without replacing every hard part inside of the case. |
