Originally Posted by Pepi
I would be interested in having my original intake repaired. What do you do if it has been sanded down too much or so much corrosion that machining it down takes a lot off? What do you guys charge for a job like this? You can PM me the info if you want. Do you mate the housing with intake so yo know it is all true and leak free?
Thanks,
Karl
Hi Karl, if it can be repaired it runs somewhere between $100.00 and $200.00, depending on the setup time more than the machining. Most end up in the $150.00 range.
After establishing a "clean" flat area for the housing/gasket you then machine the register depth for the t'stat!
Some intakes lend themselves better to clamping than others.
Thanks, Gary in N.Y.
P.S. Here's another shot of a repair underway, it's about 1/2 way finished here. You can actually see how bad it really is, the "smooth" looking areas are machined!
