#1181
Old 05-07-2017, 01:54 PM
Bentwheelbob's Avatar
The seat tracks are done and ready. They got bead blasted, scrubbed with WD-40 and green Scoth Brite, rinsed with varsol, scrubbed with soap and water, rinsed with Brake Kleen, and then sprayed with Eastwood satin clear. After that they were lubed with a CRS spray grease and their movement is very smooth. They don't look like new, but I would rather not spray paint stuff that wasn't originally painted. The seat frames are at Mitch the Powder Coat Guy's place and should be finished this week.
  #1182
Old 05-08-2017, 12:56 PM
unruhjonny's Avatar
wow!
1970 Formula 400
  #1183
Old 05-09-2017, 01:00 PM
SD455DJ SD455DJ is offline
Originally Posted by unruhjonny View Post
wow!
X2!!!! I'm continually blown away by the workmanship on this car Bob & MPD.
Dennis
  #1184
Old 05-09-2017, 02:38 PM
OVERULD's Avatar
OVERULD OVERULD is offline
Dennis,
I agree, but every time I come look at this thread, it costs me some more on my project! Cause now I'm thinking - I know my seat tracks are rusty and need to be greased...and gee, I wonder how much these seat cushions have collapsed...and on, and on it goes! Cha-Ching!
BJ
  #1185
Old 05-11-2017, 05:14 AM
Formulabruce's Avatar
Bob, Looking great !! Quick Question . Is your pedal mount date coded? Had mine in the bead blaster yesterday and noticed its dated and P/N.. Thoughts?
Name:	Bob's Pedal mount.jpg
ID:	454301   Click image for larger version
ID:	454302   Click image for larger version
" Long may we DRIVE !"
  #1186
Old 05-11-2017, 06:06 AM
Norwood's Avatar
Norwood Norwood is offline
Wow a date code that is actually a date
The Following User Says Thank You to Norwood For This Useful Post:
  #1187
Old 05-11-2017, 06:22 AM
Judge273's Avatar
Judge273 Judge273 is offline
Wasn't that a 73 and above thing? The core support, fenders, hood all had legible stamped date codes?
Mike/Illinois
  #1188
Old 05-11-2017, 06:28 AM
Could be, my core support has a clear date as well, guess I never expected it on a part like this though.
  #1189
Old 05-11-2017, 07:55 AM
Jaun - I looked through all my pictures and can't see a code in any of the pictures. The assembly is bubble wrapped and tucked away now awaiting installation. I'll be sure to double check when that time arrives. The core support did not have a date code for sure.
  #1190
Old 05-16-2017, 10:47 PM
OVERULD's Avatar
Originally Posted by Bentwheelbob View Post
I know they look like "mint" NOS, but they have been touched up and painted. A secret for installing these is to wrap gorilla tape around the tips of your slip joint pliers to keep from scratching the finish.
I did zero homework on this and just shipped them to Ssnake-Oyl. I've never heard any complaints about them other than the cost.
Bob, have you gotten them back yet? If so, curious about the quality of their work. Mine need restored badly.
BJ
  #1191
Old 05-17-2017, 06:50 AM
BJ - I did get the seat belts back from SsnakeOyl and they look fantastic. Better than brand new I am sure. The whole process was very professional. You send them your belts for evaluation. Once they arrive someone will call you after doing an initial inventory and evaluation. A few days later after further evaluation by a tech they email you a detailed quote with the scope of work defined, detailed notes on any optional work they could also do., and a projected completion date. Upon confirmation they put them in queue. I received mine 3 or 4 days earlier than quoted, but it seems like it took about 8 weeks or so. I'll try to get some pictures this weekend.
  #1192
Old 05-17-2017, 08:08 AM
PureSD's Avatar
PureSD PureSD is offline
Great work Bob! Wish I had more time to read all these threads more often and gain some knowledge.
1970 Formula 400 RAIII 4spd. Lucerne Blue 12k mile survivor
1972 Trans Am Lucerne Blue /white 4spd
1973 Trans Am 455 4spd, White, POCI Gold 2012
1973 Trans Am SD455. Brewster Green, auto, 29k miles
1948 Lincoln Continental Cabriolet V12. Restored.
1951 Willys Jeepster 6 cyl.
1970 Olds Cutlass W31 4spd Rallye Red/White
1970 Challenger RT Convert,383 4spd. Hemi Orange
1971 Datsun 240Z 4spd.
1978 Datsun 280Z Black Pearl edition 5spd.
1983 Jeep CJ7 Renegade 5spd.
  #1193
Old 05-20-2017, 09:26 PM
BJ
BJ - Here are a couple pictures of the belts post SsnakeOyl.
  #1194
Old 05-20-2017, 09:42 PM
Norwood's Avatar
Wow that's some nice work on the belts.
  #1195
Old 05-20-2017, 09:56 PM
OVERULD's Avatar
Ditto! Those look like brand new material. Are they the same belts you shipped out to them Bob? Pretty amazing work.
BJ
  #1196
Old 05-20-2017, 10:41 PM
Well, this is a bit of a marathon post. It's been a while since I updated, and today was a long day with me and MPD working until after 8:00 this evening. A lot got checked off the list, and that's a good thing.
I've been collecting seat backs to try to get two really good ones and finally did. I got the two best cleaned and painted today with SEM Landau Black and they look much better than the old ones. I scrubbed them with Dawn, scrubbed them again with SEM Soap, sprayed with SEM Sand Free, and three coats of Landau Black. Pictured below are the old and then the new ones.
The seat frames came back from the powder coater this week as well and look great. The hinge arms on the front seat backs had to be painted so I taped off the paint line based on measurements taken prior to sand blasting. After taping off the line I scuffed the powder coat with green scotchbrite and shot several coats of gloss black paint.
The console also got a coat of Landau Black today to clean it up and even out the color. I did the same Dawn, SEM Soap prep, but used adhesion promoter instead of Sand Free. I'm really pleased with how it turned out, but now need to check out all the other pieces and get it reassembled.
The biggest project was the steering column as it was in rough shape. We got it partially disassembled, cleaned up, sanded down, prime and painted. It too is looking great, but need's to dry for a few days before reassembly. The Formula Wheel hub also has been bead blasted and painted with wrinkle paint. It looks like new.
Lastly, I got a 5/16" hose stamped for the EVAP system. This hose goes on the outby side of the charcoal canister and connects on each end of the steel EVAP line that runs around the lower side of the core support.
Here's a few pictures.
  #1197
Old 05-20-2017, 11:24 PM
Pepi's Avatar
Pepi Pepi is offline
Awesome work as usual, those seat backs turn out great.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #1198
Old 05-21-2017, 06:35 AM
The Boss's Avatar
The Boss The Boss is offline
What did you use for the wrinkle paint Bob?
Finish looks spot on!
And go racin' in the street.
  #1199
Old 05-21-2017, 08:18 AM
necdb3's Avatar
necdb3 necdb3 is offline
Chris, I used the wrinkle paint from krylon. It looks perfect.
Dave
  #1200
Old 05-21-2017, 08:19 AM
BJ
The ends and buckles are original, but refurbished. The metals ends are replated/rechromed, as are the chrome buckle parts. The sleeves and boots are original, but have been recolored. The belt webbing and tags are new.
It's Eastwood wrinkle paint, which unfortunately they no longer sell. Why they quit selling great products that work like their high temp manifold gray spray paint, argent silver spray paint, and now this wrinkle finish is surprising.
