Old 06-09-2017, 10:35 AM
GTO TEX's Avatar
GTO TEX GTO TEX is offline
Originally Posted by lust4speed View Post
Proves that the old apple doesn't fall far from the tree.
Was the Carter booster pump doing its job? Your dad had problems with the RobMc not being able to supply enough fuel until we put on the pusher pump to help out.
With the Carter running it was nosing over about 150ft from the stripe and coasting through. Not sure what happened to the RobbMc because a couple of test runs went good. Thinking too that fuel level possibly was getting lower than the car liked. Got home & tested pressure and was only getting 3psi max from the mechanical pump & 6psi with the carter. RobbMc possibly returning too much fuel.
Mike Iden
'66 GTO Post/468, 700R4, 3.31 7.25@96mph 1/8
'24 Chevy 4X4 Crew RST Z71
