Old 06-08-2017, 12:30 PM
JamRSW6 JamRSW6 is offline
Default Original radiator for 70 Judge?
I am attaching some photos of my radiator. So far, I have not found out what codes should be on a correct 70 Judge, Ram Air III automatic with A/C. Anyone shed some light on what they see? Thanks, Jimmy
ID:	456476   Click image for larger version
ID:	456477   Click image for larger version
Old 06-08-2017, 01:28 PM
PM should be good (Heavy Duty).
Old 06-08-2017, 04:24 PM
Held for Ransom's Avatar
PM is the auto/HD radiator for a RAIII, but I thought the auto/ A/C radiator is the PD unit.
Old 06-08-2017, 04:33 PM
Jimmy, do you have the PHS for the car?
Old 06-08-2017, 04:50 PM
Hi John, I do have the PHS on the car. Built in November of 1969 at the Fremont, CA plant. Car was sold in CA so it has the additional emission equipment. I don't have a build sheet, so I don't know what code radiator should be there. Jimmy
Old 06-08-2017, 04:59 PM
Does it show the HD radiator option on PHS.
Old 06-08-2017, 05:20 PM
John, it does not show a heavy duty radiator option on the PHS. If my memory is correct, I believe A/C brought the HD radiator along with it.
Jimmy
Old 06-08-2017, 06:35 PM
In Eric White's book it shows the PD as for AC (as Mike said), PM for HD.
I would take this as it would be a separate option (PM) if ordered.
The PD would be the standard radiator with TH400 and RA III.
I have no idea if this is correct though.
(other than what is written in the book)
Old 06-08-2017, 10:10 PM
My notes...
BS, std. radiator, RAIII/auto.
PM, Heavy Duty radiator, RAIII/auto.
PD, A/C radiator, RAIII/auto.
Old 06-09-2017, 03:51 AM
Kenth's Avatar
Kenth Kenth is online now
Your pictures shows the correct PM radiator for your car, 70 Judge, Ram Air III automatic with A/C. .
The PM radiator is also H.D. option for non-AC cars.
Non AC cars uses the BL radiator, like my 70 Judge, Ram Air III automatic.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 06-09-2017, 06:07 AM
Looking at build sheets, I do not see a BS on any of them. I've revised my notes to indicate BL as std. radiator.
PS, anyone have a BL radiator for sale?
Here is a partial sheet of a Fremont built Judge w/ A/C...
Old 06-09-2017, 01:02 PM
Thanks for everyone's help! Jimmy
Old 06-09-2017, 04:15 PM
I went over the Assembly Manual.
BS replaced the BL and PD replaced the PM. I don't know when the change occurred though.
Old 06-09-2017, 04:23 PM
It makes since that mine has a PM and they later switched to the PD. I have an "early" car. Great detective work HFR!
