Just wondering how long it would take to put a new lares# 974 rebuild power steering box into a stock 1964 GP 389 ..no AC...stock manifolds and exhaust...Are there any mods to make ? Any of you old machanics have a book on times given for that procedure. Drive car into shop ...have them do the work....and drive home...Just so I have a ball park idea of hours.. thanks
This at best should be a 2-3HR ordeal, barring any rusted/broken hardware issues.
Overall pretty straightforward. Just for giggles below are the pages from the 1966 Motors flat Rate Manual;
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car.
The toughest part will be pulling off the pitman arm, but assuming they have the proper puller and an air wrench it shouldn't take long. You should probably replace the rag joint while you're at it,
30 minutes on a lift with the proper tools.
The difference between inlaws and outlaws? Outlaws are wanted |
if they say 1/2 an hour don't walk, RUN away.
Yup...it came with it. The guy said he had to drop the exhaust pipe on the drivers side ??? Maybe who evah made up the stock exhaust had it off a little...so maybe it was in the way...who knows....
