Old 08-01-2017, 10:23 AM
Formula8's Avatar
Formula8 Formula8 is offline
Originally Posted by hurryinhoosier62 View Post
Is your handle "64 Speed"?
No but I didn't see where he listed what cam he is running. You stated "After having seen your cam spec". So I assume you mean from another of his postings. Not a big deal, I think we are all on the same page. Probably not necessary for this application or mine but nice to have for future growth if it should come.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 08-01-2017, 11:07 AM
As noted in Jim Butler's comments in my post #3 one would have to run a very big solid roller cam to come near to 200 degrees duration at 0.200" valve lift. The top cam in his list being 282 at .050 with 195 at 0.200". Even a Comp Race hydraulic roller cam with a whopping 276 @.050" isn't close with 185 degrees at 0.200".
But that's observing the ' 200 degrees duration at .200 lift ' adage often mentioned. There is more to consider like spring pressure, and maybe the rocker arm ratio as well. But either way as Tom suggested it's a lot of cam for most street cars here.
Old information here:
