#701
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
#703
I must be getting old or something! I guess it comes down to having the street tune perfect first, plus double checking the car over again.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
#704
Skip, thanks again for your help with Dutchman axles. The upgraded rearend feels like I never touched it.
#705
On the dyno our engines get 5min of warm and checks and then let her rip. On the track (our race cars) get 1 easy pass (half throttle or so) then let her rip.
#706
"On the dyno our engines get 5min of warm and checks and then let her rip."
X2 .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
#707
I let er rip tonite...feels really good..no hiccups etc.It really feels like a lot more power..punched it in first gear doing about 5mph and instant smoke thru all the gears until I let off.Down the road a bit I stopped brake revved to about 1500 rpm nd let er loose same thing even with warm tires.
I have the in gear idle at 800 rpm now it still pulls good vacuum..still have some minor tweaking to do but I'm pretty happy. The car really lulls one into thinking it doesn't have has much power as it actually does..but boy does it wake up when you let it breathe.
#708
10.95 to 10.55, my humble prediction.
#709
I hope he realizes that large of gain, but I am going with 2/10. The previous motor was certainly no slouch!
Good luck when you get on the track again! Sent from my XT1585 using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
#710
sounds great
good luck
1980 TA 455 th400 2.56 posi [email protected] http://www.dragtimes.com/Pontiac-Tra...lip-29967.html http://www.youtube.com/watch?v=6X5XJ9PR1Qw https://www.youtube.com/user/hal101/videos |
#711
First time out I will take any gain, I would be happy getting in the 10.8's with a 10.6 as a long term goal. Weather permitting we are going Friday night and Saturday afternoon.
#712
Like many I hope it does well. After the track results consider a new thread with results and so the new people won't have to wade thru all the posts how about detailing all the changes made, including specs.
Just my .02 .
#713
Sounds like a plan!
#714
I'm not a racer, but am concerned about traction, most of all...
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
#715
#716
Glad the Dutchman axles were a go for you. They seem like real helpful folks and the only ones that would address a longer brake pilot for the discs. My 81 has them on the 3.08s also that will get a SP HR cam 455 this year so I've been watching this deal close.
