Old 09-11-2017, 09:35 PM
F ROCK's Avatar
F ROCK F ROCK is offline
Default CC'd some heads
might be cool to have a thread about your actual experience with chamber size compared with the advertised compression or chamber size; so if you've cc'd some chambers please post the numbers.
I cc'd these tonight:
1970 #11, small valves, pressed in studs, 90cc
1973 (June) #46, with stamped code 6h, screw in studs, 95cc (Not GTO heads)
1975 5C, with stamped code 8, 2.11/1.66, 98cc
Old 09-11-2017, 10:19 PM
vidguy's Avatar
vidguy vidguy is offline
My 1974 5C 4's CCed at 101cc
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 09-11-2017, 10:20 PM
77 TRASHCAN's Avatar
I calculated the compression ratio on my 1970 350 using 6 cc's dish for reliefs, .020 in hole with the 90 cc chambers, got 7.74:1. A long way from the 8.8:1 factory advertised...LOL no wonder I could run 44 degrees total timing and NOT make the thing ping. Has a 066 cam in it...
Shut it off
Shut it off
Old 09-12-2017, 12:14 AM
many birds many birds is offline
1975 5c's 101 cc after being milled for basic cleanup and valve job
1968 #15's 75cc after milling for cleanup and multiangle valve job
Old 09-12-2017, 01:27 AM
Shiny Shiny is online now
Ugh
Yes, that does position the factory claim one notch below folklore.
Old 09-12-2017, 07:36 AM
I used to keep track of this as well, haven’t done my more recent ones unfortunately.
Name:	Head Chart.JPG
2007 Grand Prix GXP 5.3L
Old 09-12-2017, 07:43 AM
I had a stock 70 350 and cc'd the heads about the same "89cc". with the stock cam it used to pump around 135psi i think.
Old 09-12-2017, 07:47 AM
On my ported 6x-8's, I had them cut .050 thou to raise the compression on my next build. I was surprised they came back at 95cc ( I was expecting closer to 90cc ). I then remembered I removed the eyebrow over the intake valve. They were 100cc before any work was done to them.
Old 09-12-2017, 07:53 AM
That chart has a mistake, the high comp #46 head was only used on the 428 motors 2 bolt main motors ,not 400s!
The 1973 #46 was only used on the 350 ,never any 400s.
The 6X heads have the smaller Exh valve as does the 5C heads.
And just for more detail, the 1970 casting #12 Head was only on the manual Trans RAIII motor and the factory literature states the CCs as being 66.
Old 09-12-2017, 08:14 AM
Yeah, that is a strange head. I can't imagine a 350 running correctly with such a big chamber that is why I questioned it. I had emailed John Wallace about it too. I have seen someone post a 73 #46 with the same chamber size, so I’m not alone.
Old 09-12-2017, 08:20 AM
I was doing some carb work on this 350 currently in my car. It pumped 125, although engine was cold.
For some reason, a few years ago I bought a set of 17 castings. I was hoping for a little higher compression head for a 350. The matched pair both measured 83.5 cc's. Better than the 11's (which I did not know till this thread, I did not measure mine when doing my build for some reason)
The 17's would get my 350 a fuzz over 8:1 coming in at 8.18:1 LOL
Shut it off
Shut it off
Old 09-12-2017, 08:21 AM
There's also a interesting 7HI 350 casting with a small Intake and a1.77" Exh .
I had a set for a few years , but never got to CC them!
Old 09-12-2017, 08:25 AM
ponyakr's Avatar
ponyakr ponyakr is offline
"...the 1970 casting #12 Head was only on the manual Trans RAIII motor..."
Some online sites disagree with that. It is said that the '70 YZ code engine had #12 heads, with an auto trans. I don't have a clue.
http://www.wallaceracing.com/enginesearch4.htm
"...factory literature states the CCs as being 66..."
Never saw any online info that low. That's down in 350HO territory.
Old 09-12-2017, 03:31 PM
Kenth's Avatar
Kenth Kenth is offline
All 1970 RAIII engines and 400M/T engines uses the #12 heads.
Attached picture shows info from 1970 Performance brochure.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 09-12-2017, 07:20 PM
67GTO4SPEED's Avatar
67GTO4SPEED 67GTO4SPEED is offline
My '68 #16 d ports cc'd at 77cc, instead of the advertised 72cc. They have some de-shrouding on the intake side, but definitely not 5cc's worth.
'67 GTO 400 HO - Ram Air - 4 speed - 3.55 Safe T Track, A/C, PS, red fender liners
'78 Lemans - Drag car project
Old 09-12-2017, 10:18 PM
I believe skip has stated removing the intake eyebrow takes about 2-3cc normally
