Old 09-15-2017, 08:56 PM
1969GiPper 1969GiPper is offline
Originally Posted by Simple Man View Post
If I let my 68 GTO sit more than a couple of weeks, I'm greeted with a sizable puddle of ATF under it. I'm told this is ATF draining back into the converter. Any solution to this, other than driving it more?
It shouldn't be leaking anything. My 69 G/P does the same thing. I've swapped out the torque converter and the converter to front pump seal twice. Still leaks. I figure it's either the front pump to trans case gasket/seal or the pump or case have a sand hole (porosity).
Old 11-13-2017, 11:22 PM
Could be wear at the front pump bushing, not a expert but did stay at a Holiday Inn once.
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
