#101
Old 06-24-2017, 10:48 PM
Bentwheelbob's Avatar
Originally Posted by 77 Canamman View Post
I replaced a couple of parts last night. My front license plate bracket was tweaked, so this nOS beauty was installed after it was given a couple of coats of SEM trim black..
I had a blower performance issue, and an annoying rattle under the passengers side of the dash. The culprit was the lower A/C duct, as is typical with many of these 2nd gens..
I used the Parts Place repro duct, which is a very close, good fitting part. The original part was not a good design to begin with. It is a fragile, thin wall plastic, with not many mounting points.
Thanks for the info. Several years ago the consensus was that this repop duct was a bad facsimile of the original and did not fit well. It sounds like this issue has been corrected. Is that right? Also, what did you use to seal the duct to the heater/AC box? I don't believe they are repopping that foam seal and would like to know what you used.
  #102
Old 06-25-2017, 10:23 AM
77 Canamman's Avatar
All mounting holes of this reproduction lined right up, and it was manufactured out of the same or very similar plastic.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
  #103
Old 06-26-2017, 03:29 PM
Thumbs up
ID:	457647   Click image for larger version
  #104
Old 06-26-2017, 03:43 PM
Looks good. Thanks for the follow up.
  #105
Old 06-27-2017, 08:07 AM
I used this to glue it to the duct:
  #106
Old 06-30-2017, 09:55 PM
When I was underneath the Trans Am while servicing it, I noticed that the clutch fork boot was destroyed. GM still sells them new under part number 14007355. Another old number was 3993851. The linkage was in great shape, as it should be with only 43500 miles. I cleaned and greased everything. The return spring was difficult to put back on the fork.
  #107
Old 07-29-2017, 08:54 AM
I found this nOS beauty for a song. Looking for the other side... GM 486051 LH rear sway bar link. The decals will be removed, and this will get a few coats of satin clear to protect its natural beauty.
  #108
Old 09-29-2017, 07:57 PM
gilg gilg is offline
The Battery in your car is a Reproduction or a topper?? this is the correct one for 1977 from factory
  #109
Old 09-29-2017, 08:16 PM
The W72 is stock other than the headers and rejet/recurve. The topper is one I made from an original R89WP battery I found in a parts car I purchased
The battery top has a 1977 date code. My car is an early 1977, so I went with this since I had it. I've seen Freedoms in other '77's.
  #110
Old 09-29-2017, 09:30 PM
Thumbs up
all the 1977 Build Sheet with standard Battery i review more than 30 even in late production 77 indicated "BATT 240" = GM 1980240 = R87P
Where you found that Topper??
ID:	464416   Click image for larger version
ID:	464417   Click image for larger version
ID:	464418   Click image for larger version
  #111
Old 09-29-2017, 10:12 PM
I made it from an original, old R89WP that was wasted. I cut the top off, and simply set it on the modern Delco battery in the car. I then used the original hold down. Looks like day one.
  #112
Old 09-29-2017, 10:14 PM
Thumbs up
Excellent good job
The Following User Says Thank You to gilg For This Useful Post:
  #113
Old 09-30-2017, 11:46 AM
Even factory ducts form parts dept. the plastic was very thin where it bolts under the glove box and breaks. I usually fill it with urethane or silicone .
  #114
Old 09-30-2017, 01:08 PM
77 TRASHCAN's Avatar
Man, I remember the original battery in my car didn't last long...
I had a couple of Die Hard's that both died hard.
Started working in a parts store in 1985.
We sold Delco batteries, they were the absolute best battery you could buy. Even my co-worker, who was a ford fanatic pushed the Delco batteries.
We had a cheaper line of batteries. I always tried to up sell the customer on the long life and power of the Delco batteries, which was the truth. Many thanked me after years of awesome service from their Delco battery.
Shut it off
Shut it off
  #115
Old 10-01-2017, 02:30 PM
Thumbs up
Originally Posted by gilg View Post
Excellent good job
Thank you. I was super happy to find it in a parts car that I had originally bought for the 455.
  #116
Old 03-26-2018, 06:19 PM
Lightbulb
More to come...
  #117
Old 03-26-2018, 08:35 PM
Poncho Dave Poncho Dave is offline
So you cut the roof yet?
Does someone remake that hurst sticker?
  #118
Old 03-26-2018, 08:46 PM
I am very close. All templates have been made, and measurements taken several times over. The interior has been disassembled.
The Hurst decal is a repro, but has been modified by me to correspond to the 12/7/76 build date of my car.
  #119
Old 03-26-2018, 08:52 PM
Good luck, but be ready to open your pocketbook. You are opening a whole can of worms, and I wish you well.
I like the inverse of the measure twice and cut once philosophy. When running trim, building furniture, or doing other fine work the best method is measure twice and cut three or four times. You can always cut more, but once you have cut too much you are screwed. I look forward to following this “journey”.
  #120
Old 03-26-2018, 08:59 PM
I’m not sure how you anticipate cutting the roof, but you may want someone to help push on it to limit it’s flexing. I’ve cut a couple, but each is getting fresh paint. It is a little scary how much they will flex. Pretty sure Hurst had a fixture as I think there are dimples left on the inner structure. I would probably cut through the middle of the masking tape as the tape would help hold the paint together to limit chipping as well. Good luck!
