Old 10-07-2017, 01:20 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Default 1000 HP @ 7000 RPM Pontiac???
I'm sure there are a few.
Anyone willing to post a dyno sheet where the engine made 1000 HP @ 7000RPM?
Calvin Hill
Hill Performance
708-250-7420
Old 10-07-2017, 01:50 PM
Stan Weiss's Avatar
Calvin,
Chris posted this a few years ago. Not exactly what you wanted.
Stan
Pontiac Pump Gas List
Old 10-07-2017, 02:16 PM
Marcella dyno sheet:
Old 10-07-2017, 02:24 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
I got 1052 @ 7000.
[email protected]. 3460#s
Old 10-07-2017, 03:32 PM
slowbird's Avatar
slowbird slowbird is online now
If you spend wisely and spend it with the right people it wouldn't be terribly hard to do.
Old 10-07-2017, 04:51 PM
cgeise's Avatar
cgeise cgeise is offline
here ya go
Old 10-07-2017, 05:21 PM
Stan Weiss's Avatar
Originally Posted by cgeise View Post
here ya go
Curt,
Do not know what the dyno correction factor was. But if the 5 column is fuel? You should have some very nice BSFC numbers what ever it was.
Stan
Old 10-07-2017, 05:47 PM
here ya go
Mr Geise, you had a true 1000 hp at 7000 rpm but the other posted dyno sheets were close (not quite there at exactly 7000 rpm)
but made the 1000 hp a couple of hundred rpm higher. Close enough for me. Good job for all who posted their numbers.
Old 10-07-2017, 07:21 PM
cgeise's Avatar
its been a while -- I don't remember
Old 10-07-2017, 07:32 PM
slowbird's Avatar
A few here, all made well over 1000hp in upper rpm range
ID:	464893   Click image for larger version
ID:	464894   Click image for larger version
Old 10-07-2017, 08:51 PM
NICE!
Old 10-07-2017, 09:53 PM
The main reason I brought this up, some guys have decided to move to the BBC combination. As we've seen over the past few years, 1000 HP is very attainable with the Pontiac engine, but not something that will come from tossing abunch of parts togther. My point is to build the engine for 1050-1100 HP which will require a well executed induction system, you can always gear the car to lower the RPMs throughout the run to increase longevity. All Pontiac engines are cylinder head challanged. The dyno sheets or combinations posted had a high end designed head, intake, cam and fuel system. These combos werent intened to peak at 7000 RPM, but much more. Raising peak torque is horse powers best friend, higher RPM's can be a killer on parts. The typical mind set in the Pontiac community is building torgue monsters and motors that don't redline above 6500 RPM.
Calvin Hill
Hill Performance
708-250-7420
Old 10-07-2017, 10:17 PM
slowbird's Avatar
Calvin Hill
Hill Performance
708-250-7420
Crazy old thinking!!!! You can turn 7500rpm all day every day without issues and no maintenance but for some reason Pontiac guys don't seem to want to believe that. I turn way more than that (cross line at 8600-8700) and haven't touch anything on mine in 3 years. I do check thinks like lash and valve springs but nothing has changed in 3 years.
Old 10-07-2017, 11:10 PM
guidos's Avatar
guidos guidos is offline
Might not meet the RPM.... this is at the wheels.
1965 GTO hard top, Black with a red interior built to drive and Race best so far 1.45 60’ 8.77@164mph . 6 Speed manual transmission. MS3pro Fuel injection Multiport , 517cubes 10 to 1, 3.50 gears, CNC E-heads wideport 350CFM by Dave B. 4025lbs with driver!!94mm turbo. Winner of the Hot Rod Dragweek stick shoot out 2017!
Old 10-08-2017, 12:03 AM
guidos's Avatar
Better photo, this is 10psi boost, 5710 RPM was max HP, 4865 was max torque.
Old 10-08-2017, 12:27 AM
Dragncar Dragncar is offline
All those yours ? The second one is very impressive. Was the top number peak HP ?
Old 10-08-2017, 09:49 AM
Dragncar, Richard is a very good Racer and competes every year in the Drag Week Event if possible. He is located in canada so he drives the car thousands of miles each year.
The Engine is a Luhn Performance Boosted Engine package.
1000HP/1000FTlbs at 5800RPM (drive it anywhere) package is very impressive.
Why I push Boost so hard. Easy on parts and easy to make the power with the right set of parts.
Luhn Performance has done a lot of boosted engines for people: California, Texas, Canada, that have been successful (Both blow thru carbed and EFI).
But a Boosted Engine like Richard's at lower rpm numbers can have outstanding durability where as a 8300 rpm engine (Trailer Queen) is obviously a different maint package.
Old 10-08-2017, 09:53 AM
BADDTA's Avatar
BADDTA BADDTA is offline
Dragncar was asking Brian...
Brian
Boobs & bacon
Old 10-08-2017, 10:10 AM
carl455 carl455 is offline
Not as easy as you think finding the right people that is!
Old 10-08-2017, 10:29 AM
Stan Weiss's Avatar
Don't know who's dyno sheets they are. But the left one sure looks like it is a cropped John Marcella's sheet from Barry's dyno (Survival Motorsports).
Stan
