Old 09-30-2017, 08:52 PM
64speed's Avatar
64speed 64speed is offline
Default Stainless OBX headers
I see them in round port on eBay for about 400 bucks give or take. Anyone ever run them? I know they will get hotter than ceramic headers but they won’t rust like painted ones. Did they clear your mechanical clutch linkage? Car is a 64 Tempest
Old 10-01-2017, 08:39 AM
cdrookie cdrookie is offline
they were $168 and change with free shipping a while back. I posted a link in the for sale forum.
Old 10-02-2017, 09:49 PM
64speed's Avatar
Boy I wish I’d seen that I would have snatched them up. As much as I’d like to have ceramic ones I can’t break the engine in with ceramic headers and I can’t afford to buy two sets of round ports
Old 10-03-2017, 09:48 PM
64speed's Avatar
How much does running these stainless headers with no paint or coating increase under hood temps?
Old 10-03-2017, 10:00 PM
NeighborsComplaint's Avatar
Still on eBay http://www.ebay.com/itm/STAINLESS-ST...lYw06W&vxp=mtr\
Are you going to run a roller cam? ... no issue w. ceramics on break in. If flat tappet, you just need a big fan in front of the radiator. I broke in my flat tappet w. ceramic headers and had no heat issues.
Also, someone was selling early large chamber Edelbrock heads NIB w. ARP head bolts in the classifieds for $2k. Maybe negotiable?
Old 10-04-2017, 12:58 AM
The passengers side runs real close to the oil filter, brake line, and along the engine block. I wrapped mine to help keep heat away from those areas.
Old 10-04-2017, 08:28 AM
I've broken in a few engines with ceramic coated headers without issues. I always set them up with a big fan in front to move a lot of air. Mainly did that to make sure engine temps stay in check, but it may have inadvertently helped the headers coatings...??
OBX has a pretty good reputation among the LS crowd for their cheap price and good fitment. I've worked on a couple of 4th gens with OBX headers and looked like decent quality for the price. On older cars, couldn't say.
Old 10-05-2017, 08:28 PM
64speed's Avatar
At 168 I had to pull the trigger. I will use header wrap if it passes the brake line too close. I am more worried about mechanical clutch linkage clearance but I guess that’s a concern with any brand.
Old 10-05-2017, 08:32 PM
64speed's Avatar
Thanks neighborscomplaint you are always on it. I have broken in headers with ceramic coating before too but all the brands say it will void the warranty not that I know how they’d know but I’d hate to buy 750 buck pair of Doug’s just to end up with some crispy coating
Old 10-06-2017, 12:00 PM
Good deal! I had just looked at them and those Edelbrock heads on the forum trying to decide whether to jump in and decided to leave my car alone for awhile.
Old 10-12-2017, 07:04 PM
64speed's Avatar
I got the headers today and I dont know if they are chinese import or what but if they fit half as good as they look it will be the best 168 bucks I have spent on the car.
Old 10-13-2017, 01:56 PM
The OBX headers don't fit, the passenger side won't clear the frame saddle, the collector is shifted to the center of the car by like 3", and down about 1.5". In my case, with a 4L80E, the collector contacted the trans pan. The flanges need a number of the holes opened up to even bolt to the head.
I have pics of where they are screwed up, I just a couple weeks ago went through this on a 68-72 A-body.
I couldn't find specific info, so I too took a chance. Fail. I did sell to a racer, was clear on the fitment, he didn't care and will make them fit, at least I got a little back out of them. Shoot, the scrap metal is worth more than what I got for them.
I posted this info in the 70-72 section, was hoping the moderator would move it to the Exhaust section.
If you're going to try to use them, start with the passenger side. That way you won't waste time with install/removal of both.
Old 10-13-2017, 04:59 PM
I figured heck a good cheap starting point for some headers even if you cut off a couple of tubes and rewelded.
Old 10-14-2017, 03:16 AM
64speed's Avatar
What car did you try to run them on? I am putting them on a 64 Tempest. I put the flanges up to my head and the bolt holes line up. The only thing I am worried about is the engine is nowhere near being done and these things look huge. That’s what I’m worried about not fitting. Since they are uncoated stainless I figure I can always heat them up with a torch and bend them as needed
.[/QUOTE]
Old 10-14-2017, 03:18 AM
64speed's Avatar
Now you got me worried but when the time comes if they don’t work at least it’s not my most expensive wasted purchase to date
Old 10-15-2017, 01:49 PM
Well, the one tube on the driver's side, like 2-3" from the flange, had a 90 degree weld in it that was like a 'V', no gradual bend, nothing, just a sharp, 90, squared off bend. Not optimum.
The passenger side was so on top of the frame that if you were to dent it, it would be half the diameter of the tube to get it to clear. I've heard some raising the engine, but that's just ridiculous in my opinion, not to mention other issues it may cause.
Since the collector on the passenger side is over to the centerline of the chassis, you would have to shorten at least 3 tubes to straighten it out. With all the welding, they would look Frankenstein by the time you were done.
I've heard a few others having success, but, it's so hit or miss, you may have to return them 3 - 4 times before you get a set you can live with. Not something I want to deal with, and pretty sure the buyer would be on the hook for return shipping. Once you open the holes up so you can bolt them up, doubt they would accept them in return.
Old 10-15-2017, 01:55 PM
[/QUOTE]
'71 A-body to be specific. Original 350 AC auto floor shift car.
Yeah, they LOOK at first glance like they will bolt up, but try actually screwing in the bolts, and you will see at least one or two holes need to be opened up. But that's not the real issues, the real issues are the collector exit, and the one tube on the passenger side that you would have to flatten the crap out of to clear the subframe/cradle.
On the collector exit, it's so far pointed towards the centerline, no way you could get an exhaust to bot up, not without something custom and looking like the Snake River Canyon.
I think I paid like $180 shipped, so yeah, not the worst waste I've ever dealt with either, and I felt it was worth a shot. I purchased these like 1.5-2 years ago, so you might get lucky. But if you look at the seller's negative feedback, and all the headers for other makes/models that other buyers have had, my gut feeling is the problem still exists.
Old 10-15-2017, 05:22 PM
mine don't bend inwards at the collector flanges.
Old 10-16-2017, 01:14 AM
64speed's Avatar
What about my plan of heating them up and massaging them? Think that would work? I am not a gambling man but at 168 bucks it’s worth a try over 800 Doug’s. I know you get what you pay for but even a blind squirrel gets a nut sometimes
Old 10-16-2017, 07:45 AM
You got lucky then IMO, good for you. Do you have more specifics regarding your experience? When did you buy them, and what's the application? You have pics?
Here's a pic of the collector on the passenger side, though it's hard to tell by the pic how far off it is. It should be centered in the cross member opening, like the other side is, and it's not even all the way lined up on the head. The trans pan prevents it from lining up on the head, but if it didn't, it would be even more towards the centerline of the chassis.
