This is my number 4 cylinder... any idea what is going on? These marks are square with the bore, so it can't be water, you can definitely feel these marks.. the home was fresh at the beginning of this season. This is the only bore that did this.. thanks for any ideas.
Chad Dammen
3500lb 10.5" tire. [email protected] with a poor 60' |
Are you running alcohol?
Have any head gasket problems? Been out in the rain?
Vp x16 race fuel
No head gasket problems No rain.. The marks are about 80% around the cylinder and square to the deck... if it was water the line would be at a angle to the deck... this is why I am confused...
Engine sit for a long time without being cranked over?
Ring faces look any different on that cylinder?
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
Is the block filled to passed that point on the wall?
All of those vertical marks are a sure sign that at least the ends of the oil ring rails need to be rounded over , a lot of fiction getting introduced there!
The longest the engine sat was 2-3 weeks if that.
Haven't pulled the pistons out yet. The block is not filled, it's aftermarket.
The ring pack is total seal classic race
.043/.043/3mm the short block turned over at 11-12 ftlbs. Well according to the cheap craftsman beam style tq wrench.
What has made you yank the head(s)?
If that's where the piston in 4 was sitting when you pulled the head, then it sure looks like signs of water to me, but I woukd not expect such to be showing rust pitting around 360 degrees of the Bore , only on the low side of the piston if the motor was sitting in a normal position. You could have a leaky valve seat coolant wise? Looking at the first shot again I see what I believe is a crack in the wall below those pit marks and just to the right of that second gas port hole.
I put the heads on at the beginning of this season , they were used and needed the valve job touched up... I just didn't have time earlier to do it so I lapped the valves and ran it... also the connecting rods are only rated to 850 hp and I was way above that, so I was going to upgrade my rods as well...
I was questioning if that was a crack also.. might have to get the block pressure checked...
If the chamber and plug from 4 look cleaner then the others then chances are it's from water.
A crack my not open without heat, a Mag test is the way to go and far faster and cheaper! Way above 850 hp by means of NA?
It made 870 n/a and I was spraying a .026 jet in a fogger.. so 225-240 ish...
All the chambers and pistons looked the same, nothing was steam cleaned...
Well at any rate that cylinder needs to be confirmed as good or bad at this point!
If needed, can that one cylinder be sleeved?
Fully agree!
I would figure that would be the fix..
Is it a thin spot with coolant seeping in from the back side?
462 Yc Block, zero deck Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR Comp Hyd-roller cam,roller lifters,springs ect. 236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6 Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut Powerjection3,T2 manifold, Try-y’s Flowcooler water pump. 71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire. 17x9 YO Honeycombs with Nitto 555's |
Pressure check along with a good sono of area. A sleeve should take care of it.
total seal gapless? did it use any oil?
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
