Old 10-28-2017, 07:05 PM
slowbird's Avatar
slowbird slowbird is offline
Must be why my car is a turd, got heavy rods in, and a crank that weighs a ton
Old 10-28-2017, 07:33 PM
grandville455's Avatar
Yea, turd , right lol
Darby
M/T 275/60 ET SS Drag Radial
Old 10-28-2017, 09:27 PM
slowbird's Avatar
My rods weigh around 850g, crank weighs a ton, don't worry to much about weight. Use the K.I.S.S method! Imo there is next to nothing in reducing crank, rod, piston weights as far as performance goes.
Old 10-29-2017, 08:16 AM
Have u tried lighter stuff Brian? To me anything that helps lighten the assembly the easier to turn n less wear n stress?
Darby
Old 10-29-2017, 08:55 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Generally that's how it starts out, the lighter the better. As you make more power you need heavier parts to stand up to the additional load. Next you have to pay the big bucks for stronger lighter parts, like ones made out of titanium.
Go fast, see Elvis!
Old 10-29-2017, 09:57 AM
slowbird's Avatar
Ive had lighter rods and crank, no performance difference, in another engine we went from alum rods to steel, no performance difference. The lighter rotating assembly seem to rev quicker in neutral but that's it.
Old 10-29-2017, 10:00 AM
PAUL K's Avatar
When you switched to the aluminum rods and saw no difference, were the counterweights turned down or drilled?
Go fast, see Elvis!
Old 10-29-2017, 10:11 AM
slowbird's Avatar
We've never had counter weights turned.
FWIW Chris U on yellowbullet has a 9000+rpm record setting bbc with 800+g rods
Old 10-28-2017, 08:33 PM
PAUL K's Avatar
Says the fairweather racer.
Go fast, see Elvis!
