Home of WFO Hyperformance Shaker induction. |
Rocky - that is interesting information that Pontiac might only started to clearcoat snowflake wheels staring in 1979 and that the colored areas were powercoated. It seems like most agree that any clearcoat applied to the snowflake wheel by the Factory was not very good.
Just wondering - what do you think of clearcoating snowflakes? Good/Bad? Is it possible for a clearcoat to last on car that is driven a lot ? Any info or experience on what might be a good clearcoat to use? Last edited by pippintook; 12-07-2017 at 12:59 AM. |
Your car will never see that harsh an envirionment.
IMO, some dirt/mud on a vintage dirt bike that gets riden maybe on the weekends & coated with wd40 then washed off right away is a lot different than car rims that get exposed to the environment of a daily driven car.
car wheels are exposed to corrosive brake dust, high heat, rocks & debris during highway or street speeds. & worse of all curb rash & lug nut/wrench damage etc. all those things will wear or damage clear coat on wheels over time. also unless you find a clear made specifically for car wheels it probably wont hold up to all that abuse. even modern factory cleared wheels start to wear pretty quickly on cars that are driven regularly. the main issue though is the chips, once it chips you can't touch it up very well, you will always see it & chances are it will start to chip & corrode under & around the chip. & if you use a normal automotive clear as was suggested earlier it will definitely not hold up on wheels. no clear & a little maintenance will look better & last longer IMO. i can post pics of my snowflakes that are just shy of 10 years old & have lots of miles on them. |
Not to change the subject but. I have a set of the early 78 15x8 snowflakes argent rims. I'm looking to restore. Does anyone know the correct formula and color for these rims. So I can get some paint mixed up. Thanks guys
the color is just called "argent." not sure on a paint code or formula but im sure someone will chime in with that info.
Your entitled to your opinion but I suggest you have experience with aftermarket product durability in both "environments" before making assumptions. Evidently you haven't since it's just an "opinion"...........
Larry - appreciate your feedback on POR-15 "Glisten" - that is one I will consider, if I clearcoat my snowflakes. Getting real life feedback on clearcoat products that work and hold up for snowflakes is tough. Many of the clearcoats look great when applied - but might not hold up that well.
78w72 - I like the idea of a high heat clearcoat made specifically for wheels and the tough conditions they face (ie. heat, chips, brake dust, etc). Do you have any specific high heat clearcoat product you can recommend ? |
The photo below of the engine in my '79......intake has been on two different engines. POR applied over 17 years ago. Looks as nice as the polished valve covers. There's your proof. Extreme high heat/environment, caustic carb. cleaner at times, along with gasoline. Don't entertain "opinion" nor "experiment" with products of questionable results. Do it right and do it once.
just wanted to point out that wheels are subject to quite a bit of abuse. when i mentioned "normal automotive clears" it was the SPI clear as was suggested earlier which is just for auto paint. ive never used POR clear, it sounds like good stuff. i dont really have any recommendations for clear as i didnt use it on my snowflakes. i have used spray clears on rally 2 rims & used a satin clear that was specifically for wheels. has held up great after 4 years but of course it will chip if you hit it with something...
my opinion was of the example given of vintage dirt bikes & mud, yes its very harsh but a very different environment. car rims are not sprayed with wd40 to protect them from dirt & brake dust etc & then washed off after every use, so that point is also moot. i have experience with many paint & automotive products & their durablity as well as owning & dealing with these cars for a long time & generally only talk about or give my "opinion" of things i have experience with, no assumptions were made. i never said POR clear was not good, sounds like it's great stuff. i mentioned the SPI clear that was suggested earlier & said normal automotive type clears wouldn't hold up. sorry if that was misunderstood... |
The paint chips I have have the blue, red and gray paint codes, the SE code I've never seen, you see body color, that's wrong. I have a nos Kelsey Hayes 7" flake, it has the correct gray on. Could have that matched, it isn't faded either. |
I think there is a Tech bulletin on the flakes, I'll look. I remember seeing something. Maybe it was hours to charge to re-do them not sure.
Matt, I'll call you. There is a 6 page tech bulletin on paints, suppliers, paints used at which factory, all the various supplier paint formulas, interior, body, non metal paints, inc wheel and snowflake, too much to post.
POR-15 "Glisten" has positive feedback. Anyone have another specific clearcoat product they used (on alum wheels - ideally, WS6) and their experience - good or bad ?
I wouldn't clear them, use magic wadding every few years, they stay great.
