#161
Old 01-02-2018, 04:21 PM
GTOGEORGE's Avatar
Yeah, but what was the weather like!
So Genius 2 cars both run 7.60 ET one on 85 degree weather and one in 60 degree weather.....what engine is making more HP? Don’t hurt yourself now!
GTO George
  #162
Old 01-02-2018, 04:32 PM
S/st 54's Avatar
S/st 54 S/st 54 is offline
Originally Posted by GTOGEORGE View Post
Who’s car?
GTO George
George,IF he dropped his motor and trans/converter in my car he would be more or less 1000lbs lighter. 4 bars more and my car would be 6.0 legal. ....I'd gladly take one for the team..and sit out a year S/ST racing to let Billy go deeeep in the 6's.....When it gets down to it those ECM guys are pretty good guys...sure they talk hella shhhhiiiiiituff but they without a doubt respect all our Pontiacs in 1 way or another...
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 1/8 [email protected] 1/4 [email protected] in St.Louis April 2026
  #163
Old 01-02-2018, 04:46 PM
GTOGEORGE's Avatar
He might give Justin a run for his money, if not out run him!
GTO George
  #164
Old 01-02-2018, 05:17 PM
PAUL K's Avatar
PAUL K PAUL K is offline
GTO George
Oh young George, please tell me which one is running Eheads?
Go fast, see Elvis!
  #165
Old 01-02-2018, 05:18 PM
Stan Weiss's Avatar
GTO George
GTOGeorge,
Do you own or use a weather station? Temperature is only one of a number of elements used in calculating DA. Also at the same DA Grains of water also matters.
Stan
Pontiac Pump Gas List
  #166
Old 01-02-2018, 05:20 PM
PAUL K's Avatar
GTOGeorge,
Stan
Stan, that's one of George's trap questions.... a LOT more information needed to give an accurate answer.
Go fast, see Elvis!
  #167
Old 01-02-2018, 05:31 PM
GTOGEORGE's Avatar
GTOGeorge,
Stan
Trying to make it simple for the simple non-racers. I hate long post. I was in Kentucky 2 years ago running an 8.50 class in 100 degree temp I ran a 8.54.....next day temp was 87 degrees out i ran an 8.46 no other changes. Point being a weather changed and I picked up almost a .10. I didn’t lose 100 lbs I didn’t make any engine changes.....just weather. So when comparing HP levels in cars everything needs to be taken in consideration.
GTO George
  #168
Old 01-02-2018, 06:00 PM
slowbird's Avatar
slowbird slowbird is offline
I personally think weather is some what of a non issue, when people run a personal best it's usually in killer air. I'd wager that almost all the ets/mph post on that chart were done in darn good air in the fall or early spring so i doubt there are huge swings to be seen. Just my opinion.
  #169
Old 01-02-2018, 06:08 PM
GTOGEORGE's Avatar
Just saying if someone is going to complain about HP in a lighter car or compare two cars they should also consider the weather conditions, some racers can't make it out in mineshaft conditions! I like to compare same day, same track results no WHINING then, takes the guessing out! Thats why I like Norwalk.....it gets most of the who's, who's of Pontiacs out there on the SAME day.
GTO George
  #170
Old 01-02-2018, 06:22 PM
JSPONT's Avatar
JSPONT JSPONT is offline
GTO George
My God George, what would be the real BIG difference? 2 cars running 7.80, one in 85 degrees the other 55 degrees .
Or 1 car running 7.80 at 2200lbs or the other going 7.80 at 3600.
You know the phucking answer you just like to stir th chit!!
As stated before by slowbird, most guys post there fastest time and I'll bet they were all when it was cool out.
  #171
Old 01-02-2018, 06:28 PM
PAUL K's Avatar
GTO George
A good tuner could've cut that difference in half.....just saying.
Go fast, see Elvis!
  #172
GTOGEORGE's Avatar
Thank you...you answered my question by not answering my question and whining like a girl.
GTO George
  #173
Old 01-02-2018, 06:39 PM
GTOGEORGE's Avatar
Do you know anything about Racing.....street boy? why would I need to tune it? Seriously I did for my 1st round, I knew I was going to run quicker (obviously), changed a pulley.
GTO George
  #174
Old 01-02-2018, 06:40 PM
PAUL K's Avatar
GTO George
Yes I do, you go when the McDonalds bag hits the ground. .....do you know anything about performance engine tuning....retired iron worker?
Go fast, see Elvis!
  #175
Old 01-02-2018, 06:48 PM
GTOGEORGE's Avatar
No, I don’t know anything. That’s why my car is junk, it always breaks and I never go rounds! LMAO!
GTO George
  #176
Old 01-02-2018, 07:08 PM
PAUL K's Avatar
GTO George
Well, if you're ever racing in my area I'd be happy to meet you and help you out. We could probably tune that Bad Boy right into the sevens!
Go fast, see Elvis!
  #177
Old 01-02-2018, 10:13 PM
Anyone remember Pat Donavan's et and quarter mile numbers?
  #178
Old 01-02-2018, 11:21 PM
Elarson's Avatar
Elarson Elarson is offline
Exactly. If everyone on the list makes a bunch of runs in all different conditions, then that minimizes weather as a variable.
Eric
  #179
Old 01-03-2018, 07:51 AM
Normally, but for some of the top fastest Pontiac guys they only run at certain races?
(like Norwalk)
It's never a mineshaft conditions then, usually not good racing conditions.
Look up Rob P posts on here for the original list he started way back.
  #180
Old 01-03-2018, 09:32 AM
The numbers are what they are. That car that day went from a dead stop through the traps and that's it. Weather weight tire size just indicates factors in the equation. Anyone who is running in the 7s with a door car is flying. It's not cheap with a light car just a bit easier than with a tank. How many times you can do this without issues shows tuning ability and correct design.
