Old 01-11-2018, 07:36 PM
vitamin c vitamin c is offline
Default 73 74 SD Head bolts
Do the 73-74 Super Duty's use washers under the head bolts? It was pointed out to me today my 74 has washers under the factory bolts and was asked if it was correct.
Old 01-11-2018, 08:43 PM
Judge273's Avatar
Judge273 Judge273 is offline
I have heard this too. From a very reliable source.
Mike/Illinois
Old 01-12-2018, 08:31 AM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Yes, that is certainly correct. It was limited to the SD-455 during the 1973 and 1974 model years. I don't know that they were used on any other Pontiac V-8s before or after.
Old 01-12-2018, 10:01 AM
great, thanks. I see the picture of the SD Engine on the cover of your book appears to show a washer under the bolts. Do you know of a replacement manufacturer? I have at least one that is cracked.
Old 01-12-2018, 10:20 AM
johnta1 johnta1 is online now
SD Washers:
Old 01-12-2018, 10:53 AM
Excellent
Old 01-13-2018, 03:55 PM
gevette gevette is offline
The one I took apart had no washers. 1974 car heads never off till last year.
Old 01-13-2018, 04:43 PM
Do you have the block date and/or the car build date?
Old 01-14-2018, 09:41 AM
I cant easily get the block or head dates codes, but I can faintly see the block casting number in a picture I've dug up it "appears" to be 1203. The Pontiac paperwork shows the car shipped to the dealer 5-10-74. Unfortunately the cast eagle crank in this block, installed by the prior owner, failed the thrust bearing test while doing a cam change. I'm having the motor gone through with a new forged crank, rods, etc..leaving no stone unturned.
Old 01-14-2018, 07:23 PM
At 1st I was going to say it probably is an 'I', but I have a lot of SD's at 'L' 203.
Probably the last batch of SD's cast?
Old 01-15-2018, 08:12 AM
The closer I look at my fuzzy picture, it very well could be L203
Old 01-15-2018, 10:09 AM
Aluminum Chief's Avatar
Aluminum Chief Aluminum Chief is offline
Default Washers
421 SD Engines used head bolt and main cap bolt washers as well.
Old 01-15-2018, 10:16 AM
Default Washers
These should work.
Old 01-17-2018, 10:05 PM
formula kid formula kid is offline
ARP should be able to find the washers.
Old 02-24-2018, 12:44 AM
Red Goat's Avatar
Red Goat Red Goat is offline
I purchased these from Fastenal. They are a perfect match.
https://www.fastenal.com/products/details/33405
69 GTO 400, 4-Speed, Matador Red
69 SCJ Mach 1 Mustang, 4-Speed, Drag Pack
72 Trans Am, 455HO, 4-Speed, Lucerne Blue
73 Trans Am, SD-455, 4-Speed, Brewster Green
73 Formula, 455, 4-Speed, Ascot Silver
73 Formula, 455, Navaho Orange Survivor
Old 02-24-2018, 07:36 AM
njsteve's Avatar
njsteve njsteve is offline
Do they have to be a certain hardness rating?
Old 02-24-2018, 11:18 AM
The factory washers were definitely hardened.
Old 02-25-2018, 01:57 PM
There was a SD455 service block advertised for sale on this forum awhile back. I remember the cast date being March 1974.
Old 02-25-2018, 05:45 PM
I should have said last batch cast in 1973.
While a lot of 74 SD cars still had 73 cast date blocks, later part of model run the 74 cast dates started.
I'd have to see when the 74 cast dates seemed to start appearing on 74 SD cars and the build date possibly.
