Old 01-28-2018, 02:41 PM
Young Pontiac Guy's Avatar
Young Pontiac Guy Young Pontiac Guy is offline
I ran a 3.08 gear in the Bird, 400, 670 heads ported, summit 2802 cam. Talked to Cliff and it easily bled off the compression with the duration. Never had a problem with it running 93. Only ran race gas if I raced it. Qjet and dual plane factory intake. Pontiac torque made it a blast with the Richmond Doug Nash 5 speed. The 5 speed was the best thing I could have done because the >3.00 1st year in the Richmond trans made up for the gear too. It ran a 14 flat with a fuel pump that was not up to par and cut out at 5100rpm in second gear. And a blast on the street. Took it on a couple 3-4 hour trips and all over Ohio. No issues, about 14mpg, and a lot of fun on long cruises.
Old 01-28-2018, 04:39 PM
Squidward's Avatar
Originally Posted by J.T. View Post
Thank you so much for everyone’s help. I would still like peoples input. It will take some time to develop a plan to execute. This is what we have so far.
• I like the Idea of doing things a step at a time. Probably start with the gearing (step 1)
• I do have the original rear in the car so it looks like I will be looking at 3.36, unless I change the carrier. Car came with 3.55, that is long gone.
• Will consider the Voodoo 703 cam. Will still look at others. (step 2)
• Will consider duel plane intake, I have a ’72 #485912 in the garage and an adaptor for the Holley. No problem going back and forth from T2. (step3)
• Rear tires are 245/60/15 that are actuarially 26.6” (every little bit helps) I could look at taller tires after I smoke these. (step 4)
• The Rhodes lifters seem like they would help but not get me to where I want to be.
• I had the distributor worked on. I have 0*@800, 5*@1200, 10*@1600, 15*@2000, 20*@2600, 24*@ 3000, 8* vac, 12* initial = 44* all in.
• I can’t imagine changing to an automatic. I love the 4sp, maybe look at a 5sp someday.
I prefer a little more initial, 14-16, a little less mechanical, 20-22, and a little more vac advance, 12-ish, off manifold vac. As previously stated, it can help to soothe a beast at idle.
Old 01-28-2018, 05:27 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Sounds like a great approach, JT. One step at a time.
I think even before you make the first change (rear gears), I would answer two other questions...
1. What type of driving do I plan to do most of the time? More Highway, or more City?
2. Will I take the plunge for an OD trans someday, or is that unrealistic?
These decisions will help determine what gears to switch to (your step 1).
Hope that helps.
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
Old 01-28-2018, 06:04 PM
Okay, good to hear you are cetain about the clutch & stick.
I agree thar the HEI tune is a great idea for dramatic fun improvement
Old 01-28-2018, 07:18 PM
J.T.'s Avatar
J.T. J.T. is offline
1. I would be doing more city/rural driving. 25-40 MPH. But would like to go an hour on the highway a few times a year.
2. In all likelihood the OD would not happen.
Old 01-28-2018, 11:36 PM
Changing the 4sp to a 5 or 6 speed gives you all the benefits without the drawbacks.
Old 01-29-2018, 12:17 AM
amcmike's Avatar
amcmike amcmike is offline
As a starting point I am looking at
• Lunati 10510702 262/268 deration 468/489 lift
• Performer RPM intake
• 3.08 gear
What would be the winning combination?
Thanks in advance for any help.
I like the choice of cam, and that with the rpm intake are a great step in the right direction. Run it with 1.65 ratio rockers. The 3.08 might be a little too low, better off with the 3.36.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 01-29-2018, 01:08 PM
What about simply swapping to an overdrive transmission such as the Magnum or the higher gear overdrive (lower numerical)? Wouldn’t that solve a lot of issues and provide you with the Cruise ability you want? Won’t have to change out that rear gear. Would maybe be just a cam swap and trans swap. Just a thought.
Old 01-31-2018, 06:44 PM
92GA's Avatar
92GA 92GA is offline
I agree. I'm running 10.5 compression on my 77 TA, .030 over 400 with 16 heads, performer intake. Don't remember what cam I put in it for sure but it was a Comp Cams cam. I'm running a th350 and 3.08 gears and the car was very lazy untill I bumped up the initial timing to 14 at about 800 rpm. I did have to limit the total using a crane cams limiter to keep it from spark knocking running down the road. Always have to use premium fuel too. I haven't driven the car in about 5 years, but I'm giving it to my son, and he will be driving it come spring. If I had it to do over I'd use a very mild cam, I'm an old man now and don't enjoy having to work on them all the time anymore.
Old 02-01-2018, 04:08 PM
#1965GTO #1965GTO is offline
I switched to a Lunati Voodoo cam in my 400 and it works great. I contacted Lunati and with my combination their recommendation was the 701LK. That cam specs are 256/262 and.455/.468.. It yields a 1000 -5300 rpm range which is plenty with cast crank and rods.
My car is a 65 with 3.55 rear gear on an Eaton posi carrier and 200-4r trans. with 26" tall tire in 3rd gear,1 to 1 and locked converter, it's running 3400 rpm at 70 mph.
With your 4 speed car I would probably go with the 3.36 gear and like others recommend a 28" tall tire. Mine has a performer with 650 carb to match. As usual you are probably at least one carb size over sized.
Good Luck
Old 02-01-2018, 04:44 PM
unruhjonny's Avatar
granted I didn't sleep at a holiday in last night;
My two cents;
Factory intake
Period Quadrajet
'744 cam
3.55 gearing
Then again, I like limiting one's self to factory stuff... and the '744 cam is arguably the best sounding one of them all.
With those heads, I wouldn't make the mistake of going to too small of a cam, that could cause issues fast.
1970 Formula 400
Last edited by unruhjonny; 02-01-2018 at 04:45 PM. Reason: needed to add another couple cents worth.
Old 02-01-2018, 05:09 PM
92GA's Avatar
I went out and looked at what I have in my engine. I have the XE268 Comp cam. It was very lazy until I bumped the initial timing up, with a 3.08 gear. It'll run with the 4th gen TAs and Camaros, have out run a few of them.
Old 02-01-2018, 05:22 PM
unruhjonny's Avatar
/\ nice point;
I had my car in a a previous configuration beat many a fourth gen;
400; 0.010 over
#12 heads
067 cam (yup, you read that right)
M22 transmission
3.55:1 posi
"leaky" '71 Quadrajet
1970 Formula 400
Old 02-01-2018, 06:32 PM
Gary H's Avatar
Gary H Gary H is offline
Agree with goatracer. That's what I would do, change the transmission to a overdrive and leave everything else alone.
Old 02-01-2018, 09:26 PM
79firebird_99TA's Avatar
79firebird_99TA 79firebird_99TA is offline
Originally Posted by Sprocket View Post
I am no expert but I did sleep in a Holiday Inn last night.
Props for not sleeping in a Motel 6.
I'm partial to my combo, but I really like the XE268 in my 400. It's choppy at idle and with the 3.08/4 speed there is nothing lazy about it around town or on the highway. At 80MPH, she spins at 3,000 RPM and my tires are 26".
Good luck.
79 Firebird/`70 400 with `77 6x-4s shaved .065"/4 speed BW ST-10/Cliff Q-Jet/XE268/3.08
99 Trans Am/383 LS1/TSP headers and catback/custom grind cam/Vigilante 2500/Strano springs and Konis
08 Corvette - Base
(SOLD) 75 Corvette/L48 350 (LSx -4L60E one day)
Old 02-01-2018, 10:14 PM
wovenweb's Avatar
wovenweb wovenweb is offline
Whew, I thought he was going to say he was puttin Chebby in it.
Old 02-02-2018, 03:14 PM
leeklm's Avatar
leeklm leeklm is offline
As mentioned by others, I like a gear ratio in the neighborhood of 3.31 or higher when running a 4spd, assuming a ~2.41 first gear. If you had the 2.56 1st gear, a 3.23 rear would be ok.
While some people don't mind feathering the clutch from a dead stop (due to a low number gear), I personally hate it. My last 4spd car had a 27" tire, 2.41 first gear and 3.31 rear. I would personally not go any lower RPM than that if you are spending a lot of time with low speed city driving.
Sent from my XT1585 using Tapatalk
