#181
Old 01-31-2018, 11:45 AM
Tenney Tenney is offline
Originally Posted by War eagle View Post
John there is no proof the June Car Life car is the Wangers red car, but no proof its not. I would like to know also.
The Car Life car is a Hardtop. No post.
  #182
Old 01-31-2018, 12:10 PM
War eagle War eagle is offline
Great catch.
  #183
Old 01-31-2018, 03:19 PM
I disagree Tenny, Not True, Both cars are Post Cars. I am old and half blind but not totally blind and can still
recognize a couple of "Post Cars" when I see them in a picture.
See Pics Attached.
Name:	CAR LIFE GTO.jpg
ID:	474144   Click image for larger version
  #184
Old 01-31-2018, 05:03 PM
Well........on the cover and in the Road Test Block pg17, those 2 are POST cars however pg 14 shows clearly a 2 dr ht. The post coupe is wearing delux hubcaps and the hardtop has spinners.
  #185
Old 01-31-2018, 06:29 PM
Here's the text ...
ID:	474199   Click image for larger version
ID:	474200   Click image for larger version
ID:	474201   Click image for larger version
ID:	474202   Click image for larger version
  #186
Old 01-31-2018, 06:31 PM
Here's the text ...
And one more ...
  #187
Old 01-31-2018, 07:57 PM
It is nice that people saved the old magazine articles. Too bad most of the time the print is so small you can't read the words and can barely see the pics. Blowing up the pics just makes the images blurred.
  #188
Old 01-31-2018, 08:06 PM
Tenny where`s the cover shot? Post car?
  #189
Old 02-01-2018, 01:27 AM
Tom posted the cover w/the post car (maybe a painting wasn't in the budget?!).
Another action-packed rabbit hole, though, is tracking the sideview mirror - and lack thereof - throughout the various images ...
  #190
Old 02-01-2018, 01:33 AM
Here's a better Car Life, Tom ...
wildaboutcarsonline.com/cgi-bin/pub9990262549620.cgi?categoryid=9950392417943&acti on=viewad&itemid=9990438454813
And some more braille type (and Blue Car press shots - PHR 03/64) ...
ID:	474235   Click image for larger version
ID:	474236   Click image for larger version
  #191
Old 02-01-2018, 01:35 AM
One more ...
Name:	11-03-2011 02;11;19PM.jpg
  #192
Old 02-01-2018, 01:49 AM
One more ...
Here's Speed & Custom 04/64 ...
wildaboutcarsonline.com/cgi-bin/pub9990262549620.cgi?itemid=9990433549148&action=v iewad&categoryid=9950392417943&page=1&placeonpage= 4&totaldisplayed=50
And CARS 03/64 ...
Name:	64 ROYAL GTO 3 010 copy.jpg
ID:	474239   Click image for larger version
Name:	64 ROYAL GTO 3 015 copy.jpg
ID:	474240   Click image for larger version
Name:	64 ROYAL GTO 3 016 copy.jpg
ID:	474241   Click image for larger version
Name:	64 ROYAL GTO 3 018 copy.jpg
ID:	474242   Click image for larger version
Name:	64 ROYAL GTO 3 020 copy.jpg
  #193
Old 02-01-2018, 01:54 AM
CARS 03/64 ...
Final few ...
Name:	64 ROYAL GTO 3 021 copy.jpg
ID:	474244   Click image for larger version
Name:	64 ROYAL GTO 3 022 copy.jpg
ID:	474245   Click image for larger version
Name:	64 ROYAL GTO 3 023 copy.jpg
  #194
Old 02-01-2018, 07:28 AM
Ah! I knew I had seen more than one picture of the 421 'Pyramid' Block and the 421 Pistons in the block in the GTO.
This was the driver's (opposite) side of the engine when the 421 engine was installed. Again the Pyramid is visible though not as clear.
You can also identify the Blue Car's Michigan Plate HJ-4471, and as you said, the lack of any outside rear view mirror.
The Earlier Blue Car also had the old style 389 SD Mechanical Linkage installed on the carbs.
They, at least, have the SD Tri-Power (Tube and Plunger) installed correctly in the picture. Plunger end attached to the Triangular Plate on the center carb.
  #195
Old 02-01-2018, 08:12 AM
Keith Seymore's Avatar
LOL! That's usually where I go first...
K
'63 LeMans Convertible
'63 Grand Prix
  #196
Old 04-05-2026, 12:25 AM
SD421's Avatar
SD421 SD421 is offline
I was just looking thru these posts again and I had a thought.
What if the Blue Car DID have a 421 as we’ve see in some of the pics/articles.
The Red car is built and Wangers thinks to himself “what if I just do an engine swap between the Blue and Red cars??
What if the Red car was running the 421 out of the Blue car??
Would you run a new 421 engine in the Red car for the acceleration test without knowing what it could do?
I wouldn’t. I would run the 421 motor thats already been tested from the Blue car.
Then the 389 out of the Red car was put into the Blue car.
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
  #197
Old 04-05-2026, 12:40 PM
I suspect not.
Keep in mind at PMD (or GM in general) if you want anything - anything at all, including a complete prototype or production engine - you just go to the parts counter with a part number and the item magically appears.
There's really no motivation to engage in any kind of shell game, especially if it results in extra work.
And if there was any concern (even though these guys build engines all day every day) you would just check the new engine on a run in stand or dyno.
K
'63 Grand Prix
The Following User Says Thank You to Keith Seymore For This Useful Post:
