Old 02-08-2018, 07:10 PM
Lee's Avatar
Lee Lee is offline
Default Borla ProXS mufflers installed, and dyno tested
After several weeks of bad weather and bad luck, I FINALLY got my T/A clone back on the dyno today.
To recap, LOW budget, Low compression 455. Unported pressed-stud HUGE chamber 66 heads, basic shortblock, Performer intake, Q-jet, HEI.
Last round of testing had the Tribal Tri-Ys (1.75" primaries) hooked up the exhaust that came on the car. That system consisted of 2.5" pipes going into 40-series 3" FlowMasters, exiting through compression bent 2" tailpipes. The transitions between sizes was abrupt and ugly.
New system is all 3", H-pipe, and Borla ProXS mufflers.
I posted a video on FB, and you should be able to view it at https://www.facebook.com/DynoTune/vi...9873204735140/
I'll have to look at my notes later, but I had to richen the carb quite a bit.
Results summary:
- Peak RWHP gain 14.44
- Peak RWTQ gain almost 9
- HP gain at 4500 rpm ~17
- TQ gain at 4500 rpm ~ 20
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 02-08-2018, 07:12 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Nice!
Go fast, see Elvis!
Old 02-08-2018, 07:33 PM
Lee's Avatar
Lee Lee is offline
Here is the graph comparing the performance with the log manifolds and old exhaust system, to the Tri-y headers and new exhaust system.
Beyond a doubt, the higher the rpm, the greater the loss of performance from log manifolds.
Old 02-08-2018, 08:19 PM
AG's Avatar
AG AG is offline
Wow, that's a big difference for that power level. Nothing like real world data.
Old 02-09-2018, 07:41 AM
cnc's Avatar
cnc cnc is offline
Nice numbers Lee...!!!!
The exhaust is it mandrel bent 3 inch tails.....???? And mufflers are they off set /centre outlet mufflers
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 02-09-2018, 08:16 AM
Lee's Avatar
Lee Lee is offline
Thanks, I'm happy with it at this point! With the compression so low (114cc chambers, .022" avg piston down the hole, beveled edge pistons) I wasn't sure if the motor could break 250 at the wheels.
The tails are mandrel bent. They are Steve Coombes' old tailpipes, from a previous system he had on his car. My exhaust guy had to make a couple of cut/twist/rewelds to get them to fit the way he wanted with my mufflers and nuances to my car.
The mufflers are offset inlet, center outlet. The headers have slip-on collectors, so my exhaust guy installed flanges at the muffler inlet to allow the system to be dropped from there. Flanges were also added to the muffler outlet side to make the tails removable. I may test that later on.
Old 02-09-2018, 08:26 AM
cnc's Avatar
cnc cnc is offline
Thanks for the info.....great build and nice looking car ......
Old 02-09-2018, 08:41 AM
mklinger's Avatar
mklinger mklinger is offline
How do you like the sound of the Borla’s? I bought them my current project but they are not installed yet.
There are no problems..only solutions.
Old 02-09-2018, 11:44 AM
Lee's Avatar
Lee Lee is offline
I like them. Compared to the RacePros I have on my other car, the sound is much "smoother". You hear them outside the car much more than you inside the car. Under light throttle under 2300rpm, it is rather quiet inside the car.
Old 02-09-2018, 11:50 AM
Navy Horn 16 Navy Horn 16 is offline
A set of decent heads would give 50% more power at least.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, [email protected] in the quarter...still tuning.
Old 02-09-2018, 12:38 PM
Lee's Avatar
Lee Lee is offline
Engine management (EFI and Ignition) are the next step for me.
After that, I may test some different intake manifolds.
Whenever the balance in my "Play money fund" recovers, then I'll do a head swap.
But for now, I'm having fun seeing how much performance I can get out of a engine that is basically a stock low-compression base engine, with a few bolt-ons and a cam designed to make the best out of what it has.
Side Note: I had a conversation yesterday, and the topic was "Engine dyno compared to Chassis dyno results." I've stated for years that there is NO simple formula, as there are so many variables. My engine has made 225hp with the stock log manifolds and old exhaust, 270 with headers and old exhaust, and now 285 with headers and improved exhaust. At any of those points, if I had pulled the motor and put it on an engine dyno with dyno headers and open exhaust, the "flywheel HP" would have been the same (after carb tuning).
There is no formula or "rule of thumb" that I have ever seen, that would have given the same "flywheel" HP when applied to those three different test results.
Old 02-09-2018, 02:43 PM
ta man ta man is offline
Nice results! Now the car has exhaust that will handle much more hp in the future.
Old 02-09-2018, 02:45 PM
What are you considering for a head swap? Just a basic low 90's cc iron head unported?
Old 02-09-2018, 03:22 PM
Lee's Avatar
Lee Lee is offline
Nope, I'll be gunning for YOU ;-)
Realistically, if a nice set of ported heads in the lower 90cc's range comes my way, I'd probably snag them and run them for awhile. Maybe keep the same cam but increase the rocker ratio.
But I DO plan to eventually get some aluminum heads that will put me in the low/mid 11's on compression, and an HR to match. It seems like chamber design keeps improving, porting as well, so I'm not rushing into that purchase. As you surmised, I'm making changes with other long range improvements in mind :-)
Old 02-09-2018, 03:39 PM
Very nice. Love the sound too! And the bumper sticker!
Old 02-09-2018, 03:42 PM
I wasn't too sure on your plans ,it would be interesting to show the difference going to smaller chamber iron heads.
Old 02-09-2018, 03:58 PM
Thought those looked like Torque Tech tailpipes.
Good job!
Old 02-09-2018, 05:26 PM
Will Will is offline
Damn Lee, that sounds great and the results are impressive.
You have the same exhaust system I'm putting on my '73, including the Tri-Ys and x-pipe except I have some Dynomax Ultraflow mufflers. I wonder how the sound will compare?
Do you have a thread or a link where you discuss your cam choice? I just popped over to your blog and read what you have and I'm curious how/why you decided on the specs you went with.
Old 02-09-2018, 06:01 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Thanks for posting all of this, Lee. It's great to see the real world results!
I'm beginning something very similar for my 72 LeMans GT, starting with a nearly identical low compression combo. After the engine install, exhaust will be next, so this is fantastic to see the details of your improvements.
Thanks again, and keep it up!
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
Old 02-09-2018, 06:17 PM
Lee's Avatar
Lee Lee is offline
Will, thanks! It will be interesting to see/hear how your muffler choice will compare.
I've discussed the cam a few times, but I'll give a quick summary. I got a CHEAP 455, and the heads were set up for the .454" lift cam that was in it. The lobes and lifters were perfect, so I knew the valve springs/heads were sufficient for that lift - so that established that parameter of the cam design.
With so many people losing lobes & lifters with "modern" aggressive cam lobes, I thought it would be interesting to see what I could do with much less aggressive profiles, and decided to go even lower on the lift. The heads have pressed-in studs, so that was further impetus to keep the lifts on the low side.
I've been using engine modeling software for several years now, and have found it extremely effective in dialing in valve timing events - as long as you have a fairly accurate "model" of the engine. I developed a model for my engine and played around until I had a design that created enough manifold vacuum, and maximized the average HP & TQ over my expected power band.
I then looked through Comp's and Bullet's lobe catalogs until I found lobes that best matched what I was looking for. I put the data for those lobes into the program, and tweaked the ICL & ECL to find the best positions. Then I called Bullet and placed the order.
At this point, the cam has met or exceeded all of my expectations. :-)
EDIT: Todd, you are welcome! Glad the data is helping you! Everyone else that has replied, thanks for the feedback and support!
