#1381
Old 12-30-2017, 10:35 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Originally Posted by wreckmastr View Post
I have to agree with this. If you peddle it to save it or just plain lift off the peddle and let the throttle blade shut there is no where between the throttle body and the inter-cooler to blow off it will split a seem in the inter-cooler. (TRUST ME) once we added another blow off on the inter-cooler on the engine side we have NEVER had another problem. I have seen pressure spikes as high as 68lbs when the car as gotten loose and had to peddle it. Here are a couple pics of the blow offs we run.
Appreciate the input guys, we'll add another BOV near the throttle body.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1382
Old 01-02-2018, 03:40 PM
twov8sandat4's Avatar
twov8sandat4 twov8sandat4 is offline
Originally Posted by 67'7F6'Bird View Post
New Photos.
More Photos online.
https://www.facebook.com/stephen.page.7568
Are you running a pump on the oil return lines for the turbos? And if so, what kind?
Panos
Little Miss G Racing on Youtube
  #1383
Old 01-02-2018, 10:17 PM
RAIV-Z's Avatar
No oil scavenge pump on the turbo drains at this time, though not out question though. The TurboWerx Exa-pump looks like a nice piece.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1384
Old 01-02-2018, 10:27 PM
So where are the oil drain lines in relation to the oil level in the pan?
  #1385
Old 01-02-2018, 11:51 PM
JSPONT's Avatar
JSPONT JSPONT is offline
When I had twin low mount turbo's I ran the turbo lines to the top of a small catch can. A fitting on each side, then I had a lower line going to the pump. It helped with cavitation, never had an issue after that.
  #1386
Old 01-03-2018, 01:25 PM
https://imgur.com/UlGkt8h
You can see the blue return line on my setup. It has a very slight pitch to it. I got to add a pump to it, because at idle and low speeds it was not draining fast enough, and was smoking like a chimney Hate to see that happening on your setup.
Panos
  #1387
Old 01-03-2018, 03:40 PM
Looks like you have a 90 degree fitting right under the turbo, that is not helping your "draining fast enough" at all.
Oil and AIR BUBBLES come out of the bottom of the turbo.
Large Bubbles and 90 degree turns do not work well, as at idle and low speed you really don't have that much oil flow to the turbo CHRA, (Center Housing Rotating Assy).
So the oil pushes past the simple seal on the exhaust side and gets burned.
You have an OK downward slope to the line but you need a smooth curved pipe drain coming right off the turbo.
A turbo like yours should have threads and also the bolt on flange. Weld a smooth 5/8" id tube bend on a piece of flat stock with a 5/8" id hole in it and bolt that on to the turbo. Get rid of the threaded crap.
  #1388
Old 01-03-2018, 04:41 PM
Yes, agreed. Right now there is a "full flow" (Earl's description) -10, 90 degree fitting right off the turbo. We had to notch the crossmember just to fit that there, otherwise it would have been the "regular" stubby 90, which is worse. In order to make it as you describe, I have to have someone fabricate a tubular crossmember there to give me the room, or go the pump route.
Either way, I thought the slope on mine was steeper than Ed's setup, and I was not happy with mine, that is why I brought it up
Panos
  #1389
Old 01-03-2018, 05:02 PM
Turbo Drains are far more important than many assume. Constant down hill slope, LARGE ID of the tube off the turbo, no screw in fittings as the fitting threads take away from the inside diameter tube size.
  #1390
Old 01-27-2018, 11:27 PM
RAIV-Z's Avatar
Final assembly/wiring is in progress. Radiators are 7-10 days out. Mandrels for cam cable driven fuel pump and crank driven alternator about another week.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1391
Old 01-28-2018, 09:44 AM
top452 top452 is offline
Looking great Ed.
  #1392
Old 01-28-2018, 04:40 PM
67'7F6'Bird's Avatar
Ed's Car is Looking Great!!
ID:	473812   Click image for larger version
ID:	473813   Click image for larger version
ID:	473814   Click image for larger version
  #1393
Old 01-30-2018, 08:50 AM
moparcolt's Avatar
moparcolt moparcolt is offline
How long till it hits the Dyno?
Chris Collier
1969 firebird, pro touring build. Full Global West suspension 474 Stroker with Molnar Crank and Rods, DCI Ram Air 5 Top end, Holley fuel injection, Vince Janis 200-4R trans
"There is no such thing as too much horsepower"
  #1394
Old 01-30-2018, 07:47 PM
RAIV-Z's Avatar
No chassis dyno eta at this point.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1395
Old 01-30-2018, 07:59 PM
RAIV-Z's Avatar
Swapped out the 90 degree fittings on mine over to 60's. If we run into oil draining issues we'll try the 5/8 tube deal. If that doesn't work I'll add a tank and a pump.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1396
Old 01-30-2018, 08:06 PM
RAIV-Z's Avatar
The turbo oil drains are ~2 inches above the full oil level.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1397
Old 01-30-2018, 08:09 PM
RAIV-Z's Avatar
Originally Posted by grandville455 View Post
X2!
Radiator's arrived.
Name:	Raven Radiators-50.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1398
Old 01-31-2018, 09:39 AM
I can't even afford to look at that stuff lol. Very nice work.
  #1399
Old 03-03-2018, 09:14 PM
Ed Page's 1969 Firebird "RAVEN" is almost done.
Name:	RAVEN and ED.jpg
ID:	477131   Click image for larger version
Name:	Raven engine  front.jpg
ID:	477132   Click image for larger version
Name:	Raven Turbos Top View.jpg
ID:	477133   Click image for larger version
Name:	Raven Engine top view.jpg
ID:	477134   Click image for larger version
Name:	Raven Oil Filter (1).jpg
  #1400
Old 03-03-2018, 09:59 PM
wreckmastr's Avatar
So the clear view oil filter will be covered by the charge tube going into the firewall? Defeats the purpose no?
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
