Old 03-25-2018, 04:49 PM
ta man ta man is offline
Looks great!
Old 03-26-2018, 08:48 AM
er455 er455 is offline
Thanks guys , This forum and members were a big help in building my car and appreciated, now I need to get some track time in to see what it will run my goal was to have a 9.50 car. So if anyone can give me advice on getting that time slip let me know , I am thinking I might go with a FAST FUEL INJECTION SYSTEM so I can run bigger injectors as I am limited with the FiTech as it only has 80lbs right now and that is only good for about 840 horsepower on E85 ...also do you think it can be done with a 3:08 rear gear and 28” tall tire with turbo 400 ????
Old 03-26-2018, 01:35 PM
Dragncar Dragncar is offline
840 HP is getting up there for a stock block. Bet it a blast to drive.
I ran these numbers through one of Wallace's calculators. 3800lbs, 840 HP, 28" tire, 6000RPMs through the traps.
It said ideal gear would be 3.59
Hope that helps. Check out Wallace's calculators, maybe put in actual weight since I just guessed.
Old 03-26-2018, 03:00 PM
dda72's Avatar
dda72 dda72 is offline
Originally Posted by ta man View Post
Looks great!
x2!!
