Old 04-09-2018, 09:24 PM
Qball's Avatar
Qball Qball is offline
Default Ring gap spec
I’m getting ready to file fit my rings in my engine and I really don’t know what the spec is supposed to be. I’ll be using the tsr-cr0690-35 file fit rings. My bore is 4.155 and stroke is 4.250 on a Race Tec forged piston.
Anyone know what the proper gap for the 1st and 2nd ring is proper?
Thanks.
Edit: this engine is normally aspirated and no nitrous.
Let me have a Diablo sandwich and a Dr. Pepper and make it fast---I'm in a goddamn hurry!
- Mike
1967 GTO
Old 04-09-2018, 09:54 PM
.004 per each inch of cylinder bore on the top ring, slightly wider on the second ring. Figure a top gap of .016-.018 and a second gap .020-.022.
Dr. Thomas Sowell
Old 04-09-2018, 10:07 PM
Qball's Avatar
Thanks, I appreciate it!
- Mike
1967 GTO
Old 04-10-2018, 06:44 AM
What will you be using to gap the rings?
If you will be using a file , only use the file to push in from the ring face to its rear, if you pull back you can flake the Moly band of the face of the ring and start ware problems right from the get go!
Also note that Moly face top and second rings ( sometimes the second ring is non Moly) should go into dry bore's and they will seat near instantly, you only need to lube up the piston skirts and have a very very light film of oil on the top and bottom of the ring.
Old 04-10-2018, 08:25 AM
chiphead's Avatar
chiphead chiphead is offline
But if the engine will be stored for some time before install, you'll need something to protect the cyl walls. I usually use WD40 or a fogging oil. For my 434 build, I'm going to use the TS AL8 ring lube and the Quickseat on the walls. Looks like really good products to promote wall prep and ring seal.
Was there no gapping instructions with the rings or the pistons??? If you're using a race-tech 2618 piston, that would indicate an application that justifies opening the rings to .0045 to .005 per inch of bore. Not much downside to being slightly too wide, and a lot of downside of being too tight. And ditto on Steve's filing instructions . File toward the inside on one side only. Lightly deburr edges with a jewelers file afteward. Keep gap square.
Old 04-10-2018, 09:52 AM
Qball's Avatar
Heck of a good question! I haven’t dug through the box of pistons and rings too much. I was holding off until I was ready to install. All my stuff is at my buddy’s place in his nice, heated, giant shop/garage. When I get back over there I’ll dig through everything and see if there’s a spec.
- Mike
1967 GTO
Old 04-10-2018, 10:46 AM
77 TRASHCAN's Avatar
I polish the edges of the gap ends with something like 250 grit wet/dry sand paper, to make sure there are no sharp edges...file might be faster...
Shut it off
Shut it off
Old 04-10-2018, 11:11 AM
Lee's Avatar
Lee Lee is offline
I just checked the notes from a 455 I built 6 years ago, using Race Tec's and TS rings. This motor was bored to 4.165". I used 0.018" top and 0.020" for second rings.
I talked with the owner about a year ago, and he was still very happy with the motor.
Oh, Total Seal makes a special lube for their rings, a light oil with a blue tint to it.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 04-10-2018, 08:27 PM
Qball's Avatar
Thanks, everyone, for the great information!
- Mike
1967 GTO
Old 04-13-2018, 09:38 AM
Glad to see you are getting to work on the engine again.
Shut it off
Shut it off
Old 04-13-2018, 09:42 AM
Qball's Avatar
Thanks, man. My block was in machine shop jail for nearly 2 years. I finally had to pull it out. Luckily, all the machine works was done and the rotating assembly had been balanced. I just need to give the block a final wash and can start assembly. Maybe before the end of Summer I can be driving this heap again!
- Mike
1967 GTO
Old 04-13-2018, 11:11 AM
Maybe by the time you get it fine tuned, the Power Tour will make a run close to you, again.
Shut it off
Shut it off
Old 04-13-2018, 12:24 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Are you going to add nitrous? If you are ring gaps should be wider. The ring manufacturer usually has paperwork in with the rings.
Old 04-13-2018, 05:52 PM
Qball's Avatar
Sigh....yeah, maybe.
- Mike
1967 GTO
Old 04-13-2018, 05:54 PM
Qball's Avatar
No nitrous. Just good old fashioned normal aspiration.
- Mike
1967 GTO
Old 04-13-2018, 06:22 PM
JSPONT's Avatar
Okay then you are good with the advise given. Good luck. There are manual ring grinders. They work well and are no expensive. They also keep the file "square"
Old 04-14-2018, 05:49 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Don't forget to check the oil rings. Ran into several batches of Total Seal standard type file fit rings sets where the oil rings butted together in the bores and had to be opened up some.
I also had a bad batch of lower iron rings show up here and they were to brittle you could NOT get one over a piston without it breaking into 2 or 3 pieces. Total Seal very quickly replaced them and didn't even question the issues we were having so I supposed they knew about it already. That was about 3-4 years ago and we've done a few since and the bottom rings were fine, but still something to keep in mind.
Far as end gaps go, for decades I set the top rings at .018" and bottom rings around .014-.016". Around 2000 we started hearing about potential benefits with opening up the bottom rings so I went to .018" on them. Zero issues before or after that move and none of our engines have ever had any problems in that area.......Cliff
Old 04-14-2018, 06:09 AM
If I am not mistaken the extra second ring gap is only needed on forged pistions , on cast Pistons having the second ring set for the same gap as the top is all that's needed and will present no problem.
Old 04-14-2018, 10:29 AM
Qball's Avatar
I will be running a forged race tec piston. That’s good info for cast vs forged piston ring gap.
Great advice on the oil rings, Cliff. I appreciate that.
Is there a recommended gap for the oil rings or is it just important that the ends not be touching? Do they not grow at all during normal use?
- Mike
1967 GTO
Old 04-14-2018, 01:14 PM
Cliff R's Avatar
Those thin expander rings aren't going to grow much way down in the bores, they just need a little clearance so they don't butt together. I just give them .020" or so, they aren't fussy.......Cliff
