| Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
#41
[QUOTE=charlie66;5875574]Seems like you're off a tooth maybe. To not be able to idle at 30 degrees sounds wrong.
I idle mine at 8 degrees..[/QU I'll know more when I get it in the car this week end. This combination don't seam to be as bad as the iron head and HFT cam was. Just don't seam to be all that responsive with the timing so low. I didn't play as much on the test stand with this one as I did the other combo. It's pulling 15 inch's of vacume Idles well. I started out with 20" valve lash and tighten to 8" int-exs GT. |
#42
I was talking about total timing too not initial timing.
Right now initial timing is at 12 degrees. GT. |
#43
At 30 degrees it shouldnt pop through the carburator ...
My Half AN Injun..... |
#44
I agree with Charlie.
You must have something else going on! GTO George |
#45
It wasn't poping true the cabs it was just lazy with real low timing.
This combo seams to be a lot better timing wise. Like I said I didn't run this that long on the test stand. This combo doesn't seam to be so lazy at 8* of timing but it did improve with a little more timing. GT. |
#46
Go mechanical injection?
#47
Just need to be in sync with the fuel and compression ratio when in boosted mode so you do not hurt stuff getting aggressive with timing. Pump Gas/ E-85 being different vs Methanol fuel. Tom V.
#48
That is something I need to do. I've got a boost controller that I want to
install, I'll have to get on MSD's sight and see what it takes to hook it up to my MSD box. I have boost refrence carbs that's a plus. It's almost together and should be running in a few hours. This thing should be pretty wild with all the upgrades. Will let ya know. GT. |
#49
charlie66, Do you take timing out as your boost raises.
And how are you doing it. I'm starting to learn more and more about this boost stuff. And what do you run for intial. timing Thanks. GT. |
#50
Whitmore 462, 670 heads 10.55@125 Same with 310 E D-ports 10.12@131 498 w/single 88 8.53@158 Last edited by Curious George; 05-12-2018 at 10:41 PM. Reason: left out info |
#51
LET THE ENGINE TELL YOU WHAT IT WANTS.
READ THE PLUGS. If you have a fast burn combustion chamber you do not need as much "Lead" (as in lead the troops) vs say a big block chebby that might want 10 degrees more timing minimum at the same load point. Has been posted before that engines are the happiest with max cylinder pressure pushing down on the pistons about 10-12 degrees past top dead center. With a slow burn deal a NA Chebby might need to have 40+ degrees of timing to be at that sweet spot. EVERY BOOSTED COMBINATION is DIFFERENT. Dont Compare your engine to your buddies engine unless they are EXACTLY identical. Just saying, READ THE PLUGS. Tom V. ps As Charlie posted massive timing retard is bad too.
#52
I raise and lower it from my laptop .. I run 8 degrees ...
#53
6.98 @ 199mph 4.53 @ 164mph |
#54
There are guild lines to follow as you tune for optimum timing while reading the plugs... With out them its playing russian roulette if you ask me.
#55
Is this your actual map that you use?
#56
Yes, But everyone's stuff is different
#57
Yellow is the timing during a run
#58
Yes i know.
I was just interested in knowing because of your unique cyclinder head.. Thanks for sharing...
#59
Whitmore 462, 670 heads 10.55@125 Same with 310 E D-ports 10.12@131 498 w/single 88 8.53@158 |
#60
On my turbo 421 combo-7.5 to 1 compression, big plenum dual carb manifold, custom turbo cam- I run 42* initial timing! It starts easily with a separate starter/ignition switch set up and runs fine, I start pulling timing at 5psi of boost and at max boost of 18-19 psi(so far) its at 27 degrees. The footbrake launch and throttle response was vastly improved when I bumped the initial up from 32*. I religously read plugs (usually cutting a couple open) and all is good. I am on a C16 type fuel and use water/meth as a chemical intercooler.
