Old 05-14-2018, 01:16 PM
Chris Petersen's Avatar
Chris Petersen Chris Petersen is offline
Send a message via MSN to Chris Petersen
Whats the entire combo?
Engine, trans, rear gear, weight or car, turbo I assume?
Fuel injected or carb?
Any data logs?
463 SRP .035 Pistons, Eagle rods, N crank, Pump gas, Victor intake, Holley 850BT carb, 6H heads,TH400 w/T-Break, Continental custom 3500 converter, 3.73 gears. TV7101 TURBO!
Old 05-14-2018, 02:01 PM
er455 er455 is offline
Any data logs?
468 SDperformance max ported 6x-4 heads ,old faithful Hyd roller cam, fitech fuel injection , e-85 , turbo 400, 9.5 3400 stall convertor , 3.08 rear gear with 28” tire , single turbo s475 , car weight is 3550 car is making 12# of boost and timing is locked out at 21 degrees no data logs
