Old 05-16-2018, 06:45 PM
JLMounce JLMounce is offline
Those pics are better. It doesn't look as bad, but it really looks like this thing is first necking down to a 3" diameter before splitting into two. So instead of going from an area of 9 sq" into a theoretical area of 18 sp", you actually neck down first to a 3" pipe at around 7 sq" of volume, before the transition to 2 pipes.
It's something to take a look at for sure. It's connected with a v band to your down-pipe. Try disconnecting the back of the exhaust and take the car out to see how it feels. If it wakes up, you know you've found at least part of your issue.
-Jason
1969 Pontiac Firebird
Old 05-16-2018, 07:21 PM
er455 er455 is offline
Good idea , I get the new balancer Tommorow and I am hoping that’s the old has slipped or was built with the timing marks off , I have read that the older professional products balancer had these issues Thanks
Old 05-16-2018, 08:06 PM
n2ogpsj462's Avatar
n2ogpsj462 n2ogpsj462 is offline
That merge sure looks like its choking the hell out of it. I also used the flowmaster scavenger series 4" to dual 3". Also used a flowmaster merge from dual 2.5 to 3.5 into my turbo. Theyre nice pieces
71 grand prix SJ 4280# 462 new for 2008 -
8.7:1 , 98cc 6Xs 246/209, 342 12bolt , BW S475 turbo JGS 50mm WG 56mm BOV. 600hp the easy way!
