#121
Old 06-16-2018, 03:07 PM
Dragncar Dragncar is offline
Looks nice. The intake, from the pics looks like it has straight runners. That little twist the CV heads have on the intake port, has it been taken out on Chiefs heads ?
Or is it hard to tell from the picture ?
  #122
Old 06-16-2018, 05:26 PM
Anderson Port Development's Avatar
Anderson Port Development Anderson Port Development is offline
Originally Posted by Dragncar View Post
.....1
... while the manifold is not perfectly straight, it's not too bad, but no manifold is perfectly straight ...
... please clarify this "little twist" you mention, i don't want to make an assumption of what you're talking about ...
"DON'T BE A CV-1 HATER... IT JUST MAKES YOU LOOK STUPID"
  #123
Old 06-16-2018, 05:49 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Very pretty! 16 injectors!! Love the intake look. I would ask questions but we all know it would start a chit storm. Good luck with the project.
  #124
Old 06-16-2018, 05:53 PM
... thank you, it's a lot of work, but please i have zero problem with questions and will answer to the best of my ability, only time problems arise is when they are asked by bias haters, which are very obvious to see ...
... if it's something i can't answer well then i won't, but i don't know what your questions are, so i don't want to assume the worst if you have genuine constructive questions ... please ask away
  #125
Old 06-16-2018, 06:04 PM
... and not sure what is happening here, as i've had issue with my original screen name in the past, but hoping this small issue can be resolved, as i'm sure everyone here would love to hear from Big Chief ...
  #126
Old 06-16-2018, 06:37 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by Anderson Port Development View Post
... you are correct, the project is very legit, and the top end is ready and will be delivered personally very very soon ...
Looks FAST! Thanks for the pictures.
Go fast, see Elvis!
  #127
Old 06-16-2018, 06:43 PM
Looking into this issue currently, I have contacted the forums admins to see what they can do to resolve it.
  #128
Old 06-16-2018, 06:45 PM
... you are the man !!! Thank you sir ...
  #129
Old 06-16-2018, 06:48 PM
  #130
Old 06-16-2018, 07:02 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Anyone know what the vapor is off of the trunk lid on Ryan's camaro?
  #131
Old 06-16-2018, 07:59 PM
When you look at a pic of CV intake ports (never seen one in real life) the ports have a little twist to them. It looks from the pic it is not represented in the T Ram.
I thought the heads were originally based on the "Twisted Wedge" Ford head. I know the first ones had Ford exhaust.
Just wondering if his heads have had some of that straightened out with port work.
Lets try and keep this from being sh!t storm. I will try if you do the same. They may not be my favorite head but I want Chief to do well like everyone else.
  #132
Old 06-16-2018, 08:23 PM
slowbird's Avatar
slowbird slowbird is online now
The twist you are seeing is the port twisted to match to side cant of the valves. Pretty normal for canted valve heads.
Im sure Bill will correct me if im wrong.
  #133
Old 06-16-2018, 08:25 PM
A twisted wedge head is not called that because of a twist in the intake port...
  #134
Old 06-16-2018, 08:53 PM
... no correction needed ... the following pics show what Brian is talking about, meaning where the valve is at, the port is at ...
ID:	485498   Click image for larger version
ID:	485499   Click image for larger version
ID:	485500   Click image for larger version
ID:	485501   Click image for larger version
  #135
Old 06-16-2018, 08:54 PM
OK, so its the chamber. Were they based on that particular Ford head ? Trick Flow ?
  #136
Old 06-16-2018, 08:59 PM
... the head used as a guide to establish a starting point for port & valve placement was the C3 Ford Yates Nascar head, not the Trick Flow Twisted Wedge head, the chamber is nothing more than a dictated byproduct of everything else in the head, just like any other head ...
... none of those Trick Flow Twisted Wedge heads (SBF or SBC) were canted valve, which makes comparison to the CV-1 totally irrelevant ...
  #137
Old 06-16-2018, 09:08 PM
OK, picture #5. What am I looking at in the top of the picture. Half a manifold or something else. ?
  #138
Old 06-16-2018, 09:12 PM
... i'm assuming you mean from post #134 ...
... that's actually an NHRA 500c.i. ProStock engine, and that is just the bottom of the manifold as it's being fabricated ...
  #139
Old 06-16-2018, 09:29 PM
... so, to more accurately answer the "Small Twist" question ... i will present these pictures for evaluation, and see what you guys decide ...
... these are various CV-1 port molds compared to a Tiger port mold ...
ID:	485504   Click image for larger version
ID:	485505   Click image for larger version
ID:	485506   Click image for larger version
ID:	485507   Click image for larger version
  #140
Old 06-16-2018, 09:32 PM
I feel the rocker bosses should be solid across/tied together. Possible fracture points in my opinion. Would also help support your spring pockets.
