#101
Old 04-21-2018, 05:16 PM
Thanks for the re-post of the article and the link to get there.
The HSD intake saw a MINIMUM improvement above the Factory RA-IV intake of 3% when we did the testing. The higher HP improvements were in the range of 5%.
I did the math on the 18 hp Edelbrock Intake improvement vs the Factory RA-IV intake (assuming a 370 HP number and it calculated out to a 5% improvement. Basically the same ballpark number as the Torquer 1 Intake. So I believe the article and the data is spot on with the info.
Thanks Bruce.
ps The Holley has equal throttle bores. The Q-Jet does not (as all know). Of course the Holley carb would work fine as the gas speed thru the barrels is less than the QJet Primaries and the air/fuel can make the turn without hitting the plenum floor. If it hits the floor, the fuel drops out of suspension.
  #102
Old 04-21-2018, 05:57 PM
taff2's Avatar
taff2 taff2 is offline
I ran an 800 Holley spreadbore double pumper on a T1 down to the mid 9's on a 400, it liked a 2" open spacer and the plenum roof entrances to the ports blended with a big radius,ran nicely up to 7000 rpm. Switching to an 850 square double pumper gave me nothing extra.
  #103
Old 06-21-2018, 08:16 AM
charlie66's Avatar
Im finally getting things almost done now. Heres a picture with the blended spacer on . Not perfect but good enough for me.. There are a couple of pin holes i got lazy with and didnt fix. So for all you critics fire away lol..
My Half AN Injun.....
