Old 06-22-2018, 06:07 PM
Lightbulb
Originally Posted by RicksGTO View Post
I've seen nice pairs 7F6 heads on here and eBay sell for under $2,000 a set most of the time. I would be surprised if they sell at that price unless someone has a late '72 GTO that really needs those dates. Most of the F-Bodies built by the strike date in the first week of April would have likely had earlier dated heads on them.
100% agree with Rick. The current BIN listing of 2750 has been listed at least 3 times, and the heads are just cores, not noted as professionally gone through with new 1piece stainless valves, new springs, and a killer valve job. To get up over 2k-2200 a pair, we're not talking assembled cores, but from what many of us have observed, for quite a few years, a pair of 7F6's need to be really clean & owner is going to have recently spent some $$$ on the above. In the last few months, on eNay, there has been at least 3 pairs of core 7F6's sell in the mid to high teens, several pairs took multiple relistings to get that.
On the block, that's a mighty early '72 auto unitized app 455 HO block, was it out of an F-body, or by chance does it have a 22P10xxxx as the partial VIN stamp by the timing cover?
Old 06-22-2018, 09:37 PM
I was thinking the YB ENGINE was standard ignition 2126 distributor. My notes could be backwards
Old 06-22-2018, 10:59 PM
yes, the very early '72 auto points coded HO block a friend has been looking for is a YB. Am always getting the two codes mixed up.
Old 06-23-2018, 04:44 PM
T/A addict T/A addict is offline
It is an F-body with a vin stamp of 22N517132
I'm not sure of the head casting date...where would that be located at?
Old 06-23-2018, 05:08 PM
Mine are moth-balled , but dated Ixx1 .
Like I011 or I101
Yours probably might be in that range too.
If you can't see the date just below valve cover mounting area -
then its under the valve cover - where the rocker arms etc are.
Thats more common on production round-port heads.
From what you have said , without #'s carb
Probably at least 4k - thats basically around core prices - but yours is running - so 4k should be acceptable.
maybe a little more , maybe a lot more if eBay goes mad about it.
If carb is legit - than add whatever price those are worth.
To the 4k
Old 06-23-2018, 06:54 PM
I've never been sure which block codes got which distributor in the 72 HO cars, so I just did some research. I found the following information in Rocky Rotella's new book, "The Definitive Firebird & Trans Am Guide: 1970 1/2-1981", (page 71) which, states:
Code / Transmission
YB / Automatic with K65 Unitized Ignition
WM / Manual with K65 Unitized Ignition
YE / Automatic with points-type ignition
WD / Manual with points-type ignition
I found another source (online) which gave the same info. It's the "Original Firebird and Trans Am 1967-2002...The Restorers Guild" by Jim Schild (page 72).
Old 06-23-2018, 09:01 PM
Wallace site - YB = Unitized , also.
damd buncha drunks
Old 08-21-2020, 06:32 AM
Old thread but realized I hadn't posted the head dates... both are 1101
Old 06-23-2018, 06:49 PM
Has to be a Trans Am because that was the only car available with standard ignition with the HO engine
