Old 06-29-2018, 12:22 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by Jay S View Post
Sorry Paul, I see those specs for the 302h-2 you found don’t match the 308h-2 they offer right now. Only the .050 are the same everything else is different. I remember seeing that they had date codes stamped on the back end of the cam but I don’t recall how specific it is. Not even sure if they all have it. Sounds like measure time.
Jay
No problem Jay, we're all just trying to help the OP. A picture of the grind number would help make a positive identification. I'm not sure it matters much, regardless of the exact specs it's completely the wrong cam for his application.
Go fast, see Elvis!
Old 06-29-2018, 07:04 PM
Hillard's Avatar
Hillard Hillard is offline
Don't disagree with you at all Paul. I was only going to use it because it's what I had. However, I've since obtained a Comp 276AH-10. Should be a lot closer to working well with my combo than the Crane.
Old 06-29-2018, 07:13 PM
PAUL K's Avatar
I agree H. and understand. I'm glad you found something that was a better choice. That Comp should do well for you.
Go fast, see Elvis!
