Old 07-22-2018, 02:30 PM
I guess what I am trying to figure out is are they one of the old billet HP heads they used to make before they were cast or are they a newly made head with improvements.
You could come to Norwalk and find out yourself, instead of 2nd hand info.
Old 07-22-2018, 03:38 PM
Dragncar Dragncar is offline
Sometimes 2nd hand info will have to do. As long as it is good info.
I would like to see Norwalk some day. But the 2K or so I would spend on the trip needs to go towards my engine.
Intake is coming up, Marcellas not cheap. But I get a work of art back so its all good.
Old 07-22-2018, 03:47 PM
Billet usually means solid piece you can carve into anything you want. .I doubt the old program would be duplicated. Why would you? If they are used originals I doubt they'd be used as ported back then.
Doesn't seem hard to figure.
Old 07-22-2018, 03:51 PM
GTOGEORGE's Avatar
OK........update the car has "Solid cast" (no water jacket) HP's on it, not Billet!
GTO George
Old 07-23-2018, 03:28 PM
GTO George
Kinda what I was after George. Do you have anything else on the heads or just more engine info ?
Are they a "wide port" High Port. I did not know they made solid HPs like the Tigers. You would think if someone want to do a big port job on a solid head, well you have more to work with.
Billet crank ? How big a huffer does it have ? Is it a KRE built engine.
Do you have a estimated horsepower you can share ?
Going to be at least 2 blown Pontiac powered funny cars at Norwalk. Bet its going to be a good time.
Old 07-23-2018, 03:42 PM
GTOGEORGE's Avatar
Most of your questions have already been answered. You just need to look.
Yes its built by KRE
Yes it has a Billet Crower crank
Yes they are BIG flowing solid High Ports
Yes it has GRP rods
Yes the engine has gone 7.40's in a 3,450 non-chassis car
Yes it has a BIG Supercharger on it
Yes the new car weighs over 1,000 lbs. lighter
GTO George
GTO George
GTO George
Old 07-23-2018, 04:12 PM
Elarson's Avatar
Elarson Elarson is offline
How much more incentive do you need to make the journey?
Eric
Old 07-23-2018, 10:52 AM
Stan Weiss's Avatar
I wish them the best of luck.
I just don't ever see it happening. Ever if reducing weight by 100 pounds is a .1 second reduction in time (which it is not)
3450 - 2300 = 1150 pounds reduction
7.40 - ((1150 / 100) * .1) = 6.25 new et
Stan
Pontiac Pump Gas List
Old 07-23-2018, 11:42 AM
They get a reduction for minus weight
then the advantages of mid-engine FunnyCar chassis
then aero factors of body
then whatever additional gypsy voodooo magic newly added under the hat
= 5.973 with the Newton calculator
(Fig Newton - not Isaac)
It must already be doing some lazy low 6's if they feel 5.9's coming
Old 07-23-2018, 11:54 AM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
I just don't ever see it happening. ..........
I have an idea. They'll probably be out in a few weeks, so let's wait and see. Is that OK with you??
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 07-23-2018, 12:18 PM
Stan Weiss's Avatar
Jim
Jim,
I hope they can / do. But GTOGeorge has made this like playing 20 questions. I can only base what I posted on that information. Clearly if they have modified the engine since the 7.4 @ 3450# or if there were any problems on that run which cause it to be slow than it would be a different story.
Stan
Old 07-23-2018, 12:24 PM
GTOGEORGE's Avatar
Jim
You're so right!
GTO George
Old 07-23-2018, 01:03 PM
Elarson's Avatar
5's are more difficult on the track than they are on the internet. Ask me how I know.
Best of luck to them. It's fun to see more Pontiacs pushing the ET envelope.
Eric
Old 07-23-2018, 12:23 PM
GTOGEORGE's Avatar
Stan
WOW....theres a lot of other things that need to be factored in (other car was not really a chassis car and had the area of a brick)! I'll answer any questions, i was very busy on sat & Sun.........kinda still am.
GTO George
Old 07-23-2018, 01:23 PM
Stan Weiss's Avatar
GTO George
GTOGeorge,
All valid points.
The Title of the thread is question. I gave my answer. I am sorry if some people do not like that answer.
Yes, in a couple of week we should have an answer from real on the track performance.
Stan
Old 07-23-2018, 02:40 PM
JSPONT's Avatar
JSPONT JSPONT is offline
GTOGeorge,
All valid points.
Stan
Don't be sorry Stan, when someone needs math, they will be asking you to do your magic! The thread was like pulling teeth, very little info with a photo and 5 seconds in the topic area. Like that has been done a lot here. SMH
Old 07-23-2018, 03:09 PM
GTOGEORGE's Avatar
GTOGeorge,
All valid points.
Stan
Who said I didnt like your answer? Just surprised! He's just going to get his feet wet at Norwalk!
GTO George
GTO George
Old 07-23-2018, 03:38 PM
Who said I didnt like your answer? ....
GTO George
I think he means me. I didn't like the answer because it just used the old "100#=.1 second" formula that's been around since I was driving a 16-second car. It's a gross over-simplification and we might have real world results soon, so why bother with crude estimates? I just looked it up: alcohol funny cars (not Pontiac-powered, of course) have run at least as quick as 5.41 with some very restrictive rules.
Looking forward to a new quick Pontiac-powered car.
Jim
7.75 @ 178 pass:
Old 07-23-2018, 04:28 PM
Jim
Yeah that old formula is definatly NOT Linear...
