Old 08-18-2018, 07:23 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
Originally Posted by 1969GiPper View Post
Sorry if this has been asked before. What “brand” of transmission pan gasket seals the best? Transmission is a 1969 Turbo 400 and the pan gasket seems to always be leaking/seeping. Also do you use the gasket “as is” or do you coat it with gasket sealer or RTV? If sealer or RTV is used do you let it “set up” somewhat before installing? How long before you fill with fluid? Do you put sealer on the bolt threads? Any special tightening sequence? Basically want to know your secrets.
Thank you in advance.
I'm no expert but have done a few pan gaskets in my life. #1 is to make sure the pan is straight! People OVER TORQUE PANS AND VALVE COVERS! When they over-torque they distort the sheet metal at the bolt holes.
Secondly, ensure all old gasket material/adhesive/rtv/ whatever is removed prior to installing new Fel pro gasket with no rtv/adhesive/whatever. The only way I would use anything on the gasket is in a vertical application where you need to hold the gasket in place to get the bolts started.
Karl
