Old 09-20-2018, 09:02 AM
Sirrotica's Avatar
Originally Posted by Va68goat View Post
I don't know if this will help identify a problem but here are a few pictures of the flexplate after we pulled the motor to address spacing of the windage tray. This flexplate was used on the other motor that was in the car when I bought it. I sent the flexplate to Paul and he balanced it,. When I got the motor and flexplate delivered, I painted the flexplate before we installed it. So after Paul balanced it and I painted the flexplate, I would say I put about 100 miles on the car. As you can see, a spacer was used. I don't know if any of this is helpful...
From the pictures it doesn't appear to have cracks in it, although looking at a picture isn't optimum for a diagnosis on this matter. Usually there is rust around the cracks in a flexplate making the cracks stand out, as well as fine metal powder from the 2 edges fretting against each other. The cracks are very obvious in any I have seen, you don't need a magnifying glass to see them by any stretch of the imagination.
Based on the pictures I would say as I earlier posted that it's not a cracked flexplate, but I believe it's in that area of the engine/transmission. Based on the video I watched with the camera/phone moving around under the car while it's running.
For the people that hadn't seen the shim in question between the flexplate and crank flange, it's fairly well illustrated in your first set of pictures.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Closed Thread
