Old 10-03-2018, 07:43 PM
I say we start a Raffle ... $5 buys a guess, half the pot to the owner, half to the guy that guesses the closest to the actual source of the noise.
I'd bet its crankshaft related, something is rubbing.
Bill Nye.
Old 10-03-2018, 08:31 PM
gtofreek's Avatar
gtofreek gtofreek is offline
I seriously doubt that unless it's external.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 10-03-2018, 08:45 PM
I run all the manifolds over the belt sand table. Unreal how uneven those things are. Afterwards I've always used either steel or copper for a gasket and never a leak.
You guys have already cut the filter apart and never found anything, oil pressure is rock solid. Tells me the inside of that engine is just fine. I believe what ever it is, it's outside the engine.
Just listened to the video and it sounds like it's at the rear, but hard to tell because the camera never stays in one place for too long. Matter of fact once listening to that video, my youtube popped up a whole bunch of similar noises just like that, and everyone that I watched that had comments stated it was in the flexplate. One video in particular could have been laid over your video and you couldn't tell one apart from the other. It was a straight 6 cyl jeep Cherokee, and he found out it was a flexplate. Thought that was funny.
Old 10-04-2018, 11:52 AM
I hope it is too. I hear a "double tap" and I dont think there is anything else that can cause it. Especially after the converter bolts have been checked/verified. I would think if its flex plate related, you would see some sign of a crack, like a rusty spot or be able to push or pry on the plate in a way to make a noise.
Bill Nye.
Old 10-04-2018, 12:53 PM
Is the oil filter by-pass (in the filter adapter) still intact and functional?
IMO As it should be for a street car.
And why do people keep posting "no metal in oil"? Where is that info coming from?
Wish all the videos were back up and people would try to cypher through relevant posts and pictures by the OP and the hands on folks that have been helping him.
Also, while this car is in the air...please check crank end-play and turn the engine by hand to feel for that loud clunk clunk that happens when the engine gets cut off.
Tryin' to be nice
Clay
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
Old 10-05-2018, 09:14 AM
Va68goat's Avatar
Va68goat Va68goat is offline
Few more
ID:	494349   Click image for larger version
Old 10-09-2018, 04:59 PM
torqhead's Avatar
torqhead torqhead is offline
Ok, I'll ask as I'm sure many want to know here.... What happened this past weekend on this deal?
Old 11-06-2018, 01:12 PM
Va68goat's Avatar
LeGoaT/As,
Thanks for your message. I just responded back!
aceaceca,
I've done a visual inspection of the flexplate while it's on the car and I don't see any evidence of cracks. I'm hoping that none of what you described has occurred..hahaha. This motor has less than 200 miles on it. It hasn't been right since the day I started it. I'm hoping to get things looked at this weekend. grivera, has a good point...there's no reason to pay to have the flexplate replaced if we pull the torque converter back and it's still knocking....you guys agree with that?
Old 11-06-2018, 01:58 PM
Originally Posted by Va68goat View Post
LeGoaT/As,
Not sure I agree, it might only knock with a load on it from the converter. Also, if there's something the flexplate is striking on revolution, with the flexplate off, could see witness marks.
Old 11-06-2018, 02:36 PM
grivera's Avatar
grivera grivera is offline
That's my point - if it only knocks with the load on it from the converter he will know when converter is pulled back. At that point we can assume it's either the flexplate or the converter. If the sound continues after pulling the converter back I don't see how it could be the the flexplate because the sound is very random in nature.
Will Rivera
Old 02-05-2019, 01:39 PM
STEELCITYFIREBIRD's Avatar
ABSOLUTELY No blame on the “cooks” at all...just get it back to the Chief Chef!
Awesome that these great guys here helped you, something rare these days indeed!
A Testament to the Great company we keep here.
You’ve exhausted external possibilities it appears.
Old 10-04-2018, 04:12 PM
Va68goat's Avatar
dataway,
What does that mean? "turning or firing at half crank speed." What causes that?
I just got home and I'm going to post the videos from when the motor was first started to the last few tests that were conducted.
Closed Thread
