I think torque converters rob a little bit depending on what you have. A stick shift car will put a little more on the dyno, but can be slower at the track. That's why no one races dyno's. (except in the race section here! LOL)
Little more going on there. For starters, the PS rules dictate a stock style exhaust system must be used, with the only exception allowed is upgrading to 2 1/2" pipe. In other words, my 70 Formula has to maintain it's transverse system. The other factor I was getting at was the muffler itself. The Flowmaster transverse is still a large case chamber muffler, the same muffler everyone says kills HP. The Pypes transverse is actually a dual muffler system in disguise. If you look at it's design, each pipe is a straight through design and separate from each other, with it's own packing, it's just wrapped up in a single case package. Each pipe continues as it's own. It's not even close to being like a real transverse muffler system, yet it's in a transverse package that provides excellent ground clearance on these vehicles that were really never designed to have mufflers hanging off the floor boards. As far as how fast people have gone with it??? I've seen quite a few in the 10's at 125+ mph. It's an excellent transverse system. However at our power level (1funride and myself) it's not worth anything over the Flowmaster transverse. Been there done that. Would it pick up with a 3" system??? Maybe, but rules dictate 2 1/2" in my case. Besides that, it wouldn't be an honest comparison between mufflers if the pipe diameter was change too. 1funride isn't going to see any gain with the exhaust system whether he sticks with transverse or a dual muffler setup, unless he increases the pipe size. My car is an excellent example of that with about the same power level. Last edited by Formulajones; 10-07-2018 at 01:54 PM. |
^ He is not competing in any class that I know of, so no reason to NOT increase pipe size, and gain power.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
Bingo.......good reading
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.45 @ 88.1 mph on slippery street tires.Bad 2.19 60ft.Owned since 86' |
The op has sparked a fun discussion, and I agree with the comments that sometimes we get too hung up on the dyno #s. My 79 T/A has never been on the dyno but I might give it a go just to see what it reveals as to dyno vs track. The Olds 403 in my car is nothing fancy; stock crank and rods, hyper pistons, mild HFT cam, 226/233 with 1.65 rockers and owner ported heads. C.R. is at 9.4:1 and 93 octane is more than enough. Other details in my sig. Power steering belt stays on even for 1/4 mile passes. Anyway, car will run 12.20s in the heat and has gone 12.01 in good air. I did spend some time doing some things that I would classify as 'blue printing' but nothing beyond the basics of ring gap, bearing clearance, etc. I haven't changed anything on the car or motor for years and it just keeps on ticking. I think your combo is/ will be a blast and offer plenty of fun and performance as you tweek the variables. Good luck.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.60 @ 126 so far... |
My brother worked at an import tuning shop and they called their dyno “the heart breaker”. I saw many people show up with import and domestic engine combos expecting big numbers and get disappointed by the results. Like it was said earlier a great tuning tool.
I'm actually in the low 300's for RWHP at this point and haven't touched the exhaust. I feel he'd be spending a large chunk of money chasing HP with an exhaust only to be disappointed. Especially considering 3" on a 1st gen isn't fun to fit either and opens other issues. I'd be more concerned with straightening out the rich AFR he says it had first. Depending on how much fuel trimming is needed he may find 5-10 HP right there. But quite frankly, like I said earlier, I've seen other Pontiac 400 builds on the dyno that also were in the 270-280 RWHP range so I don't see any real big concern. Take it to the track. Depending on what it weighs (1st gens are relatively light) his HP level should give him some easy low 13's with decent conditions. That's doing pretty well with a mild 400 Pontiac. Last edited by Formulajones; 10-07-2018 at 06:23 PM. |
Remove the flex fan & install a clutch or electric, less parasitic drag.
Improvements to go faster you ask?
Rotating mass wherever it's found on the car just eats up HP like it's going out of style, be it in the mass of the Rods, Pistons , Crank and flywheel , or the rims tires and brake drums on the car and is many times overlook looked for shinny new 320 plus cfm ported heads and big Carbs!
Working from memory but if I recall about an 8.3ish and 83 mph, my 60 foot times were terrible with wheel spin. Had a nitto 555 tire on there with posi, the tire just wouldnt do much. Best run was very 1st when the light changed and I wasnt ready, I just hit it and it actually did OK. I think the tires actually degraded past the 1st run, but of course since the first run seemed to grab I tried to load the converter a bit, that resulted in smoking the tires and having to pedal it. Then it became loading the converter some, take off and getting out of throttle when inevitable tire spin started, then back into it partially, then full throttle. I gave up on trying to get a clean pass as it just wouldnt hook up, and in some instances I spun through the first 2 gears and the car started going sideways. The tires generally restricted my passes to 80 ish mph and just wouldnt allow more power to be applied/
Those 1/8 mile #s could be 12.80s in the 1/4 and with decent traction who knows how well it might run. Nothing more frustrating than having the power but not being able to put it to the ground.
Doug's Header's 3 inch gate cutouts...who cares what you have behind them. 30 extra hp with a flip of a switch.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, [email protected] in the quarter...still tuning. |
I am having a nasty resonance with the flow master transverse muffler at 40mph. I am thinking of changing it for just that reason, at times I like it, but most of the time now I either slow down or speed up to get past it. I seen several flow numbers for flowmaster vs other mufflers, and the flowmaster look to flow much less, in some instances less than 50%. Hard to believe it can be that bad. The ultra flows seem to flow exceptionally well, but I am a little concerned with true duals fitting without scrapping as my car sits lower than stock. I didn't know how the Pypes transverse muffler flowed with the race pro muffler, which seems to be closer to 2 single pipes in a single package. I like the ultra flow dual setup.
So the Pypes transverse from my experience will typically work just as well as a dual muffler system, because that's essentially what it is, and without all the ground clearance issues. Getting back to your drone issue, I found the same thing with that Flowmaster American Thunder transverse setup. They are exceptionally loud. Years back they also offered the same thing called a "Force II" that used a quieter muffler with more chambers. I've run both systems and the Force II was much quieter and didn't drone. That's the last system I had on the bird before I switched to Pypes. Unfortunately Flowmaster cancelled that system many years ago and now only offer the American Thunder, which technically should flow a little better than the Force II I was testing with. Last edited by Formulajones; 10-09-2018 at 12:40 PM. |
Formulajones, yeah I think your correct. It seems logical that the Pypes (RacePro) would flow better as you have a congiguous flow rather than all the changes in direction and waves/turbulance hitting one another. There is a point where all that begins to play in and you loose power, for me I think a new exhaust is needed, I dont mind it louder on outside of car but the inside droning is terrible.
I "think" the Pypes Race Pro muffler would also flow better than the Dynomax transverse muffler, as it appears the dynomax transverse muffler is similair to an X pipe and there would be some wave fronts hitting. If someone disagress with this logic and has real world experience please let me know otherwise. Im going to throw out a few more questions in general. * Max HP limit of Pypes Race Pro 2.5" transverse systems before it restricts, I estimate 450 simply becuase it's a 2.5" system? * Does anyone have real world experience/opinions with the Pypes Race Pro transverse muffler as compared to a true 2.5" dynomax ultraflo system with seperate mufflers? Just not sure if I can fit a true dual system in a lower sitting Gen 1 firebird without scrapping. * Opinion on Tom Hands prior system which I beleive was 3" out of collectors, 3" through the X-Pipe, then reduced to 2.5" using flowmaster cone reducers, then 2.5" into and out of a Pypes transverse muffler? |
There are limits but I've seen several of these Pypes Transverse systems on 10 second cars. There are quite a few of them in the FAST series as well running 10's and mid to upper 120's on F-bodies.
Yes my feeling is the Pypes race pro transverse flows better than the Dynomax. I've used the Dynomax too, but no testing with it. But I do like that muffler better for it's sound qualities. I've also run the dual muffler system in 2 1/2" as I mentioned, it was no better than the Pypes transverse. Not at our HP level anyway. However if you go changing the pipe sizes you may find something. Only problem is though, on a 1st gen, and even a 2nd gen, the 3" stuff is a tight fit. It doesn't tuck up into the driveshaft tunnel very well, which in turn makes the mufflers hang even lower, plus the muffler cases are larger because of the larger pipe diameter, then snaking 3" pipe through the leaf springs back there becomes a challenge. They almost always create tire interference as well when it comes around the gas tank. Some aftermarket gas tanks are notched here just for this purpose. The only kit I've used that I really liked in 3" for a 1st and 2nd gen is Torque Tech. It actually fit as well as could be expected, But they are no longer in business unfortunately. My father runs something similar to what you describe on his GTO. He runs a 3 1/2" off the header collectors, and into a Dr. Gas "X" pipe that reduces the pipe to 3" coming out of the "X". That's the best way to reduce pipe size. Then he runs a typical 3" A-body system from there with race mufflers and tail pipes from Torque Tech. Actually a very quite system in the car, no drone. I've done other similar things. For instance on our Z I run the Pypes transverse system but I wanted a stock appearance out the back so I substituted the tailpipes for factory 69 Z tail pipes in 2". Reduced coming out of the transverse muffler. Not only did this give me a factory appearance but it did a couple other things. It freed up a ton of room around the gas tank and leaf springs, it also allowed me to use the factory tail pipe hangers, and it also mellowed the sound of the Pypes system to a point where my wife is very happy with it. Yet it's highly doubtful the change cost any measurable HP because you're at the very end of the system where pipe size isn't critical, and it's only a short section of about 1 1/2 feet of pipe with very little bend in it. There are tons of options depending on the sound level you want and how much work and money you can tolerate. But from my experience it's not worth spending the money if only chasing 5-10 hp. Unless you jump up in pipe size and want to deal with all those issues, then I think you'll find some gain. I have tons of sound clips with examples I've mentioned but it doesn't sound like that's what you're after. |
#38
Formulajones, I am absolutely interested in sound clips, if you have a means to share that isn't too much work that would be fantastic.
#39
What he said same goes for engine dynos. My RAIV 400 with a 288/296 UD made 385 engine HP on a very conservative dyno through headers and mufflers and ran mid 12s @ 109 weighing 3900 lbs. My 455 made 400 rwhp and with some tuning at the track ran 10.90s @124 weighing 3750. Current pump gas 455 made 525 HP on a Stuska engine dyno runs the same as previous 455 and formulas show more like 550-570 hp engine HP.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
#40
https://youtu.be/uIFkggwDY-8 https://youtu.be/lCmw-yDq73s https://youtu.be/er1z7PpqsnY Here is my wifes Z. Using the exact same Pypes transverse exhaust. This is with the 2 1/2" tail pipes supplied. https://youtu.be/5dTNw93VPEQ Here it is with 2" factory tail pipes from the muffler back. Tamed down the deep rumble but the most noticeable difference was inside the car. https://youtu.be/IZ0HlEY7b74 Here we are cruising Route 66 going 65 mph and 2800-2900 rpm. Can hardly even hear the engine running. Tailpipes made all the difference in this one. https://youtu.be/7a3lMwoM-7c Here's a ride along in my fathers car with a custom exhaust system that consists of different manufactures. It's 3 1/2" off the collectors into a Dr. Gas "X" pipe. the "X" reduces on the back side to 3" into a pair of very small 12" long race mufflers (forget the brand at the moment) and into a pair of 3" torque tech tailpipes. Inside the car it's extremely quiet with no drone, and does a surprising job of keeping his 571 at a tolerable level. https://youtu.be/YYoXURd5rM0 Here's a shot outside, and at full throttle it makes some noise out the back, but compared to the ride along above, it's amazing how quiet the car is inside. https://youtu.be/Ah_LjF_Sxow Here's another Pypes transverse I did on our Ventura with a rowdy 10:1 406. Left the 2 1/2" tails on this one. It made some noise behind the car but cruised very nice with no drone. This is the car that had a true dual exhaust system on it in 2 1/2". I didn't like how the mufflers hung below the floors so I ripped that off and installed the Pypes transverse system. There was no improvement (or loss) in performance with this car switching from true duals to the Pypes transverse system. https://youtu.be/47HgejCVbFs Last edited by Formulajones; 10-10-2018 at 11:09 AM. |
