Old 10-18-2018, 11:16 AM
JMB36TA's Avatar
JMB36TA JMB36TA is offline
Originally Posted by "QUICK-SILVER" View Post
Need to try this again
Like Greg said, don't choke the engine out. Just start restricitng air flow to see if the engine idles up or idles down.
Also might need to check for more vaccum leaks.
This car got the hot idle compensator on back?
Clay
I choked it out but as I slowly covered it I didn't notice any change in idle until I got close enough for it to die.
I've been checking for vacuum leaks over and over and haven't found anymore. All vacuum lines are new. I haven't checked around the carb since I put it back on Monday night so I'll check that again. But I had this problem before I took it off that night.
Yes it has the hot idle compensator. It's off an Olds so it has this little spring and rod sticking out the back. I sealed around it so there's no leaks according to Cliff's instruction. Maybe I should find a new compensator and cover?
