| Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
Going to run a Q jet, spreadbore nitrous plate and a RPM intake on my 434. Do I need to notch or otherwise modify the divider on my RPM intake when using a plate?
Nobody?
Is notching the divider not required when running a nitrous plate or carb spacer? I assume the extra space between carb and intake helps the sides of a dual plane intake "see" each other? Would you not want to notch an intake used with nitrous, to prevent a cylinder from stealing mixture?
If you use a spread bore nitrous plate, my opinion is you would need to modify the plenum walls to remove the "step" from the Q-Jet pattern to the Square Bore Manifold inlet.
If the Nitrous Plate is the typical thickness, the Throttle Blades should be high enough to clear the side walls without issue. You do the mod for air flow, not for clearance for the throttle blades. The divider wall (with the NOS plate height), should allow for the rear blades to clear the center divider. Tom V.
So basically I would need to lay back the intake's carb pad so it matches the contour of the plate's outer walls?
Yes
TV
I ran a RPM with a n- plate and a 4150 carb for years with no problems.
You should be fine. GT. |
Nos plate probably designed for a Holley carb and RPM intake. He is trying to run a Q-JET Carb with a Q-JET NOS Plate on a square bore manifold. The center divider will not be the issue, the issue will be the edges of the intake opening. Tom V.
It would be a good idea to thin the plenum divider some. Most spray bars have a few discharge holes pointed directly at the divider walls.
Only a pawn in game of life. |
Correct, the RPM accepts spreadbore carbs but has the 4150 bolt pattern too. I did lay the opening back and knife edge the center divider to clear the spraybar pattern. I had to gouge and blend the carb pad at the ends of the center divider, so the spray pattern will spray down the plenum.
Picture says a Lot. That looks really good now. Glad you posted the picture and I can see that you are using a Holley Spreadbore NOS Plate. Totally slipped my mind about you posting the NOS Spreadbore plate being there. DOH! So used to Squarebore Holley stuff.
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 11-21-2018 at 03:57 PM. |
I've still got an old Moroso Qjet N2O plate system I put on my 78 TA when I had the stock motor. Felt like another set of secondaries kicking in-which that 180 HP motor needed!
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
