Old 12-15-2018, 11:33 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Here are a couple of pics of what a correct main oil feed should look like.
Yes sir.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 12-15-2018, 11:34 PM
Thank you for that report and results from real on-track experience. This adds validity to my impressions after carefully looking those crankshafts over at PRI last year. Visually, to me the oiling circuits in the crankshaft are world's apart from the Eagle stuff and other off-shore offerings. I just hate the huge "winking eye" depressions Eagle uses to move oil from block to mains and then the rods. The Scat oiling looks similar to the way quality billet cranks carry oil. I will likely be buying a 3.25x4.25" Scat forging for my street car based on what I have seen and your experiences. Good info.
No problem just trying to help out. Your info is very valuable as well. Billet cranks are pricey now adays.
1.079 4.52 155.15
3000 lbs
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 12-15-2018, 11:55 PM
Kevspontiacs@aol.com's Avatar
[email protected] Kevspontiacs@aol.com is offline
Originally Posted by Jeff Kinsler View Post
Yea I will not post it for the reason above but anyone can send their stuff there to get it machined. I think it actually was talked about on py somewhere and people were saying that's not a good way to do it.
I bet I can guess the players in that one Lol
Old 12-16-2018, 12:49 AM
Better pics of Eagle stuff.
Mike, that is pretty common even in the production side of engine remanufacturing. Like you, it doesn’t strike me as a precision machining operation.
Dr. Thomas Sowell
Old 12-16-2018, 01:26 AM
bad69bird's Avatar
bad69bird bad69bird is offline
I think that should be prerogative?
That's fine on BES thing.
It's probably well known anyway to most builders.
Goes along with Quality machine work
Haha got me on that one! Damn phone! Lol
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
Old 12-16-2018, 02:49 AM
Dragncar Dragncar is offline
Got mine, tested steel batch. Thanks Tom V.
Will see how it does with billet steel rods.
Old 12-16-2018, 03:03 AM
Douglas Willinger's Avatar
Douglas Willinger Douglas Willinger is offline
Here is a pic of what Eagle main oiling looks like. Essentially, a rough, giant trough, carved into the crankshaft journal. No scoop or lead into the direction of crank rotation. So large, the depression takes valuable support area away from the crankshaft. Many of the cheap Chinese shafts utilize this low cost approach of feeding oil to the bearings. If your making a few hundred HP with a V-8, probably works OK. NONE of the quality crankshaft manufacturers use this cut rate approach to oiling. Crower, Moldex, Winberg, Bryant, and now apparently Scat, choose to oil the mains properly with carefully designed scoops and directional oil flow. Not the best place to cut corners IMO.
That is what an engine shop told me in Connecticut earlier this year about the aftermarket forged steel crankshafts SCAT is OK. But avoid Eagle's because the cross drilling holes are poorly done.
As far as I know, SCAT is the only aftermarket forged steel crankshaft offering for a 3" main journal with 4" stroke for Pontiac, so that is what I purchased for my 1970 Trans Am "434" project. Am pleased to here read of people finding that SCAT makes some great alternatives to far more expensive billet cranks.
https://butlerperformance.com/i-2445...tegory:1234870
I see there is an aftermarket forged steel crankshaft with the 4" stroke for the 3.25" main journal Pontiac block. But not by SCAT, but another company "RPM"
https://butlerperformance.com/i-2445...tegory:1234872
How is the quality on that piece?
Such a size offering could be useful for a destroked 455HO or SD455.
Additionally, MOLNAR offers some options for the 3' main journal Pontiacs, with strokes of 4.25", 4.375", 4.5" and 4.65"
http://www.molnartechnologies.com/cr...m-pontiac.html
How is the quality on those compare with the comparable size SCAT 3" main journal crankshafts (4", 4.25" and 4.5" strokes)?
How do the SCAT ($799) and MOLNAR ($983) 3" main journal, 4.25' stroke offerings measure up, e.g respective weights?
And has anyone have any experience to share particularly about those more uncommon choices as the 4.375' and 4.65"
1970 Lucerne Blue Firebird Trans Am, deluxe blue interior. Original Ram Air III, M-21, 3.73. Being built as a 4" stroke "434" with SR 614 Ram Air IV heads
1972+ Lucerne Blue 4-door hardtop "what if" T-41 Le Mans Sport GT/Grand Am concepts. Equipped with future 3" journal "455 HO"/"what if" prototype "SD 455".
What if GM had continued production of the 1970-72 GM A body somewhere in the southern hemisphere?
Old 12-16-2018, 11:10 AM
John Langer's Avatar
John Langer John Langer is offline
That's a start but from what I have learned, I wouldn't run my junk like that.
Old 12-16-2018, 11:43 AM
Mark G Mark G is offline
I have a scat crank with tons of work done to it Oliver billet rods no problems ,,
Old 12-16-2018, 11:50 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Looks like a brand new engine not sumn that has got that crap sprayed out of it and buzzed to 8500+
[email protected]. 3460#s
Old 12-16-2018, 12:15 PM
it show when you have good machine work done and a engine builder to knows his stuff.. We have a shop like that here in Canada many NHRA Wally line the walls and they put my motor together in 2012 check it last year still like brand new..
Old 12-16-2018, 12:26 PM
Lee's Avatar
Lee Lee is offline
Great information!
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 12-16-2018, 03:06 PM
mgarblik mgarblik is offline
Always interested in improving our durability. If you have any pics or tips to improve our oiling further and will share, I would be interested. Currently, a crankshaft that looks like that is working for us with additional bearing and system mods, but there is always room for improvement. We run higher load than your engine, but lower RPM. When things are working correctly, we don't see over 8500 RPM. If I remember right, you routinely run 8800-9000 RPM?
Old 12-16-2018, 04:14 PM
Moldex version from several years ago
Old 12-16-2018, 06:48 PM
Pics of crank
1.079 4.52 155.15
3000 lbs
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 12-16-2018, 10:34 PM
Pics of crank
Are you planing on running the same crank when you upgrade your heads ?
Old 12-16-2018, 11:48 PM
I was but just sold the rotating assembly and am getting a great deal on a crower billet.
1.079 4.52 155.15
3000 lbs
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #38
Old 12-17-2018, 01:03 AM
Crower billet is a good piece... that's the crank we ran in the funnycar... 9200 rpm shifts and a lot of boost... never had an issue.
Ran .005 on the mains and .004 on the rods.. had some trick oiling mods done also...I forgot the % but it was over balanced... never hurt a bearing...not one.
  #39
Old 12-17-2018, 01:20 AM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
Thanks for sharing your results Jeff, it means a lot to help other Pontiac racers.
From what I know I think you've done a great job without center counter weights. I think you're right on edge of knocking the center mains out without your RPM but block stiffness is a big deal. I moved to a fully counter weighted crank on my junk but I'm planning to run higher rpm.
Thank you again for sharing some real information.
  #40
Old 12-17-2018, 01:48 AM
There are times when it pays off being a Pontiac racer that wins and goes rounds. Manufacturers want to be associated. Goods deals or free stuff never hurt anyone.
