Old 12-16-2018, 03:12 PM
shaker455's Avatar
Default Building a one off Qjet
I'm working on a neat project and though I would share some of the build.
I've had a lot of success in the past with my single ring 71' 455HO Qjet that I modified years ago to go along with the current combo in my 71' Trans Am.
I had another forum member approach me with a box of parts asking to build something from them which I like to do for his combo.
I like the SD-455 Qjet and I'm modeling it after that...like to call it a "Super SD"...
Combo is very close to mine, another 455HO with 10.25:1 & nice VooDoo roller.
I usually do not mix parts but I think this one off deal will be cool.
I'm going to use a 74' Pontiac airhorn & Base with a Buick 800 main body.
Also removing outer booster rings and then extend the main booster like my HO to help enhance the reduction in signal strength.
The pieces will be recolored and plated and choke will be converted to elec.
I'll post some pics..
Old 12-16-2018, 03:27 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Good stuff, thanks for posting
Go fast, see Elvis!
Old 12-16-2018, 03:44 PM
69FIREBIRD76MM's Avatar
Mr Shaker, doesn't removing the bigger booster affects the instant throttle response in a negative way?
Old 12-16-2018, 03:53 PM
shaker455's Avatar
Not if it's calibrated correctly Mr 76MM.
The regular Qjets do not have extended booster like the factory single ring.
Old 12-16-2018, 04:06 PM
very nice, idea on price when done?
Old 12-16-2018, 05:15 PM
shaker455's Avatar
No prices & winter project.
Old 12-16-2018, 06:05 PM
frankyboy455 frankyboy455 is offline
Can you elaborate on "extend the main booster" ? I know a 71 HO has no booster outer ring, but what about "extend the main booster" ???
Old 12-16-2018, 06:13 PM
I am guessing a sleeve.
Old 12-16-2018, 06:30 PM
shaker455's Avatar
no sleeve,
I'm going to machine an extension that will attach to the booster and come to the same length as the HO,
Old 12-16-2018, 06:49 PM
Oh I did not know the HO had a longer booster. I always thought the only difference was the missing outer ring.
I've had quite a few of those HO carbs over the years and never noticed that. Learn something new every day !
Is that "extension" so to speak supposed to increase the signal ? Can and will you post pics ? That sure will be interesting.
Love to see Quadrajet tweaks !
Old 12-16-2018, 07:10 PM
shaker455's Avatar
Yes I will post more pics and as I go.
If you look at the HO the inner booster extends about as far as the outer ring on regular units.
The extension does not have to be a straight diameter, it can have a taper to it to enhance sheer or venturi effect.
ID:	500351   Click image for larger version
ID:	500352   Click image for larger version
ID:	500353   Click image for larger version
Old 12-16-2018, 08:25 PM
shaker455's Avatar
The outer ring works like a shear step on the bottom of a Holley HP downleg booster:
Standard downleg w/taper on left, middle HP downleg, Annular on right
An Ebay unit someone cut outer ring from
ID:	500368   Click image for larger version
Name:	sony camera 2 396.jpg
ID:	500378   Click image for larger version
Name:	sony camera 2 394.jpg
Old 12-16-2018, 09:05 PM
Jeff have you ever tried welding on these castings?
I'm just curious how it would work, never had time to try it.
Possibly silver brazing would be better?
Or maybe tig brazing with silbronze?
Old 12-16-2018, 09:12 PM
shaker455's Avatar
The castings are zinc so welding may do damage.
Old 12-16-2018, 09:29 PM
Very cool project!
Old 12-16-2018, 09:55 PM
shaker455's Avatar
Yes I'm liking it!
Old 12-16-2018, 10:03 PM
catc's Avatar
catc catc is offline
i'm anxious to see how this turns out and photos along the way!! !i enjoy seeing the Q-Jet Mods and am very grateful for members showing us and sharing some of their secrets...Thanks Jeff
Old 12-16-2018, 10:14 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Since Curtis and I both run Q-jets I will be tracking your progress, Jeff. Always something new to learn everyday.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.60 @ 126 so far...
Old 12-16-2018, 10:36 PM
shaker455's Avatar
Hey Mike & Gates!
This is a cool project and I've been wanting to do this for about 8 years.
I may run a similar assortment on my 67' GP but that's all stock so outer booster rings will do.
I'm currently machining open & rebuilding the plenum on an old squarebore P4B plenum that I have to also accept QJ.. along with removing exhaust crossover and separate water crossover.... another test mule!
I'll machine out the rings first then come up with a booster design that will fit and secure well.
Old 12-17-2018, 09:40 AM
77 TRASHCAN's Avatar
Damage to the person welding.....
Shut it off
Shut it off
